Old 15th May 2006, 07:08 AM   #1
Default horn with low compression ratio
I'm trying to make a bass-horn 55-300hz with two 15" for channel just straight no folding for better hi frequency. Since efficiency isn't the goal there are others reason why I should make a compression chamber in front of the cones? Why not just use horn throat area like Sd for cleaner hi freq response??
Old 15th May 2006, 05:07 PM   #2
GM is offline GM  United States
GM's Avatar
Greets!
As long as the horn +driver's response is flat enough or you're willing to use EQ, then a 1:1 CR is fine, but the bigger the throat, the bigger the mouth for a given BW, just look at old Altec, etc., truncated theater basshorns.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th May 2006, 06:50 PM   #3
What FLA do you suggest I made some modelling with 0,74 and 1.
Old 15th May 2006, 07:31 PM   #4
GM's Avatar
Greets!
'FLA'? This means 'full load amps' of a motor to me, so may not be enough for your app. If you're referring to its flare factor ('M' or 'T') though, then it depends on the driver's response and how much distortion is acceptable. If low distortion is required, then a long conical seems appropriate with a >75 deg included wall angle. Tractrix is popular, but a 55 Hz flare unloads around 78 Hz, so a ~39 Hz flare is required to load it to 55 Hz, with exponential being the 'middle road'.
GM
Old 17th May 2006, 03:04 PM   #5
I intend Flare factor.
I run those numbers on hornresponse
Old 17th May 2006, 03:06 PM   #6
hops, before this
Old 17th May 2006, 10:45 PM   #7
bear's Avatar
Consider a Hyperbolic expansion horn? The benefit is that if you null the reactance with the back volume, you get a bit lower in freq response... iirc, down to the flare freq, or was that the mouth freq...?
Imho, I don't think you'd have much if any serious HF loss with the use of a compression "orifice" at the thoat... I presume ur only looking to get up into the lower midrange? I hope... carefully folded horns do ok up to 300Hz... fwiw. Think "scoops".
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Why does a compression driver need a horn? Defo Multi-Way 39 6th January 2010 03:18 PM
Compression ratio and diaphragm size in compression drivers inkasound Multi-Way 50 8th January 2009 03:38 PM
Why, horn, compression chamber? tade Subwoofers 8 28th April 2005 06:04 AM
Horn loaded compression design JnEsPappa Multi-Way 2 8th May 2003 04:08 PM
Page generated in 0.08366 seconds (74.33% PHP - 25.67% MySQL) with 11 queries
