ultimate budget speaker - Page 2 - diyAudio
Old 15th May 2006, 01:28 PM   #11
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
You say you "want to take the strain of the FR125s"
Go buy some more FR125s, and they will have to move less
Old 15th May 2006, 01:35 PM   #12
inrank is offline inrank  United Kingdom
inrank's Avatar
i love the idea of 4 either side which would look cool, but i cant afford 300 for 6, i have read a lot of the Bipole designs but i dont have enough room behind for that, so what about just two firing front both running full range?
although it would be sealed, from the calculations on WinISD, i think i want a little more bass, F3 around the 55-60Hz
Old 15th May 2006, 01:45 PM   #13
You will have to make frontbaffle so that the distance from both drivers to your ears in your listening position is exactly the same
Old 15th May 2006, 02:02 PM   #14
"more bass", you say, OK!
Buy four WR125, they cost less - and then make a simple two way with crossoverpoint between WR and FR somewhere between 300 and 800 hz
Old 15th May 2006, 02:30 PM   #15
inrank's Avatar
sounds good, but buying 8 WR125S's is only 30 cheaper than 6 FR125S's
Old 15th May 2006, 04:15 PM   #16
NO, I mean 2 x WR125 pr side for bass and 1 x FR125 for midrange and up
Old 15th May 2006, 04:17 PM   #17
inrank's Avatar
ah ok, cool
so shall i go sealed, or is there another type that is siutible.
Old 17th May 2006, 12:49 AM   #18
Well, there is a bipole minionken on planet10 made for two FR125
It should work with both drivers on front
There are other bipoles shown, where you can get an idea about cabinetsize fore two drivers
Personally I might try with a big widebaffled closed box
http://www.planet10-hifi.com/boxes-CSS.html
Old 17th May 2006, 02:47 AM   #19
adason is offline adason  United States
adason's Avatar
or you can try basszilla-like speaker, fullrange on open baffle, woofer in the box
i made a few myself with various driver combinations, highly recommended
http://www.blackdahlia.com/html/tip_45.html
Old 17th May 2006, 09:21 AM   #20
diyAudio Member RIP
another option is to go 0.5 way with a FR125S+WR125S(0.5) per side.
One advantage of bipoles is they do not have a baffle step in the response.
If you put both drivers on the front it needs to be a 0.5 way for Baffle Step Compensation.
/sreten.
Best budget speaker cable rick57 Multi-Way 22 13th February 2006 03:03 PM
Budget PA Speaker - HELP!!!! seekingwisdom Multi-Way 10 14th January 2005 01:50 AM
Best budget speaker for beginner? Eric Y Multi-Way 18 31st March 2003 03:20 AM
I need help with a low budget speaker dilema akcb3 Solid State 10 13th April 2002 06:57 AM
Copyright 1999-2017 diyAudio
