How much deeper will these dig?
Old 11th May 2006, 03:06 AM   #1
mazeroth is offline mazeroth  United States
Default How much deeper will these dig?
I have four Dayton RS315HF subs I was going to use in my dipole Orion clone. I also own four Ascendant Audio Atlas 15s that I was about to sell. I got to thinking about maybe using the Atlas 15s instead of the Daytons in my dipoles to allow my dipole bass to extend even lower. My question is, how much lower would the increased Sd provide me? I'm guessing not much, maybe 5hz more extension at the same output level. One minus with using the Atlas subs is my speakers would be 3" wider, which would probably look kind of stupid.
Thanks!
Old 11th May 2006, 03:48 AM   #2
sdclc126 is offline sdclc126  United States
sdclc126's Avatar
Well, how about using the Daytons in the Orion clones, but keep the Atlases for stereo sealed subs below 40 hz, as Linkwitz does with the Thor subs? Or do you already have sealed subs, or simply aren't going to use any?
P.S. - curious - what are you using for mids & tweets? And are you doing active?
Soft Dome
Old 11th May 2006, 01:12 PM   #3
Late to work so quick reply.
Tops will have MTMs with Dayton RS180s and RS28 tweeters. Active crossover duties will be handled by my DCX2496.
I have an IB sub right now with four Adire Shivas (1500 ft3 room, so I can get away with it). I'm thinking the Dayton RS315s would be sufficient and would allow for the speakers to look nicer.
Work JUST called me I gotta run!
Old 12th May 2006, 12:10 AM   #4
sdclc126's Avatar
Well you have plenty of bottom end - keep the Daytons and sell the Atlases for sure. Your design sounds great - please share it with us as you build and definitely show us the end product.
I think there are a lot of ways to go OB and I've thought of using the 12" Peerless SLSs for the bass units - yeah not as much excursion but I don't know that I would ever push them that hard. Thought of doing a line array for the uppers - maybe with the Hi-Vi B3S + supertweets, or the SEAS L18 / 27TBFCG combo ala Zaph, maybe in an MTM.
Ah, so many possibilities, so little time - and money...
Soft Dome
Old 12th May 2006, 01:00 PM   #5
Zaph is offline Zaph  United States
Zaph's Avatar
Default Re: How much deeper will these dig?
Thanks!
Keep in mind the Atlas 15's have much more "air noise" than the RS315HF. I've used both. The Atlas is a nice driver, but it's free air motor noise is not very good at all and it really needs to be in a box. The RS315HF on the other hand is nearly silent at full Xmax and would be better suited to dipole.
I made these observations while breaking the drivers in. It was full Xmax, free air.
-Zaph|Audio-
Old 15th May 2006, 01:35 AM   #6
Cyrus_s is offline Cyrus_s  United States
... Or redo the IB with Atlases, sell the Shiva's and do the original plan with the RS's.
How much deeper will these dig?Hide this!Advertise here!
We need deeper bass response than the lowest pitch frequencies Brian Beck Subwoofers 34 16th March 2006 11:17 PM
Already have a prebought sub/box/amp can I mod it for deeper bass? dcourtney Subwoofers 23 1st July 2005 04:15 PM
Phono preamp- how to modify to get deeper LF? MaciekP Tubes / Valves 4 15th March 2004 10:13 PM
Copyright ©1999-2017 diyAudio
