Old 10th May 2006, 06:13 PM   #1
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
Default i'm confused ...
i got this table :
power vs SPL
1watt = 90dB (before cabin gain)
2 = 93
4 = 96
8 = 99
16 = 102
32 = 105
64 = 108
128 = 111
256 = 114
512 = 117
1024 = 120
2048 = 123
4096 = 126
now , if i got a 16W speaker , it can make 102db spl ...
my question is , at what frequency?
does this mean the spl is the same for all 20-20k freq range?
if you are not living on the edge you are taking too much space
Old 10th May 2006, 06:21 PM   #2
Did it Himself
richie00boy's Avatar
No the 90dB you have been quoted can either be a wideband white noise signal, or more likely, a really high point in the frequency range to give an exaggerated sensitivity figure.
Once you factor in that in the bass region you are on the roll-off curve it all goes down anyway.
Also the SPL at the bass end will depend on your specific box design and can vary hugely.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 10th May 2006, 11:20 PM   #3
Send a message via MSN to noodle_snacks
bearing in mind that power compression etc isn't taken into account, or cone excursion then a better equation to use would be:
efficiency+10log(power) eg 90+10log(16)
Old 10th May 2006, 11:40 PM   #4
sss's Avatar
i got a horn in the alarm system that says 125db...
so thats bs i guess , right?
Old 11th May 2006, 12:55 AM   #5
lndm is offline lndm  Australia
The horn is probably optimised for a limited frequency range. 125dB is probably the maximum (anyway, it is probably meant to be used at one level only).
Old 11th May 2006, 01:03 AM   #6
If you have the T/S parameters, this link http://www.adireaudio.com/Files/Tech...lculations.pdf
will help you find the actual reference efficiency, although like mentioned there will still be many variations.
Confused about DVC and Q mashaffer Multi-Way 13 30th July 2006 04:40 PM
Confused - Can You Help? Steveal Full Range 16 1st July 2006 09:59 AM
Help Confused jwatts Subwoofers 2 26th June 2006 12:12 PM
I'm Confused and I need your help. Paprika Solid State 12 22nd September 2003 08:49 AM
Page generated in 0.09186 seconds (72.91% PHP - 27.09% MySQL) with 10 queries
