diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   What is better: low or high sensitivity microphones ? (http://www.diyaudio.com/forums/multi-way/79072-what-better-low-high-sensitivity-microphones.html)
Web Wolf 6th May 2006 08:39 AM
Hi boys. I'd like to ask to you what do you this would be better between high and low sensitivity in measurement microphones. I mean: I have not only to know a linear response but I want to measure the exact SPL in ambient with the better transient response and the higher precision.
High sensitivity means that the membrane can output much more voltage than a capsule that have less sensitivity, but what is the most praecise capsule ? Yes, a less sensitive microphone requires much ampification (and it means more noise) but does it means a more stable capsule and better transient response ?
I've seen DPA 4090 (B&K capsule) and Earthworks M30 (20mV/Pa agains 8mV/Pa).
And what does it means the sensitivity error -34dB+-2dB ? Does it means that the SPL value measured is wrong of about 2dB :eek: :eek: :eek: ?
Bye
myhrrhleine 6th May 2006 06:58 PM
Sensitivity won't matter much for your needs.
Look for wide bandwidth.
Also, once you calibrate sensitivity error won't matter either.
Web Wolf 7th May 2006 09:16 AM
OK, but I'm speaking about the resolution in changing between one SPL level to another. Now im not speaking of tracking an SPL curve but of measuring SPL exact values. I wanted to know (if possible ;) ) if a better sensitivity or lower sensitivity can improve resolution of SPL measurements.
And do you know what is the sensitivity tolerance expressed in dB ?
pinkmouse 7th May 2006 09:29 AM
It depends what you're testing. If you need to know the SPL of jet engines, PA stacks running at full tilt or drumkits, you need a low sensitivity mic. If however you are testing domestic speakers, acoustic instruments or background noise, a high sensitivity mic would be more appropriate. They are different because they are used for different purposes, one is not intrinsically better than another.
myhrrhleine 7th May 2006 10:35 PM
There is no relationship between sensitivity and resolution. The microphone will have far greater 'resolution' than you can use, regardless of its sensitivity.
Copyright 1999-2017 diyAudio
