Old 4th May 2006, 02:57 AM   #1
ruerose is offline ruerose  Canada
Default Zaph XG18 design questions
I was pumping the numbers for zaph's XG18 MTM (http://www.zaphaudio.com/audio-speaker16.html) into WinISDPro to double check some curves and see what effects volume changes would make.
I have a concern mabye one of you folks could answer.
1. The excursion of these driver's in the standard vented 2 cu ft enclosure listed show it will only handle about 35W of system power before reaching overexcursion in the 50hz range. Seems like a very small amount of power considering the driver's lower efficiency.
I had to input driver specs manually, I guess my question is in WinISDPro the Xmax I entered was 5mm as listed on Solen's website. Should I have entered 10mm for peak-peak instead?
How does WinISD want to see it?
A last curious question about this system: Can this system play loud? Not rock-concert loud, but louder than my CSS FR125's Singles? They bottom out before my ears do, and it's not really enough to fill the room and down the hall. (12'x20')
Old 4th May 2006, 04:10 AM   #2
I added a 6.8 extremis to the program using the same methodology and it looks like performance won't be an issue, SPL and Extension at "safe" excursion levels are really close. I can push the Extremis further, but I want the mid-range performance of the pair of XG18's. The XG is cheaper too.
Old 4th May 2006, 09:55 AM   #3
Default Re: Zaph XG18 design questions
Yes, /sreten.
almost complete zaph Vifa XG18 / Seas 27TDFC MTM chainenoble Multi-Way 12 23rd December 2010 06:06 PM
Questions on a Zaph Vifa XG18/Seas 27TDFC MTM build cwujek Multi-Way 3 28th January 2008 03:06 AM
Zaph L18/27TBFCG design questions Dave Bullet Multi-Way 28 3rd September 2007 02:40 AM
KIT261 vs. Zaph XG18 ruerose Multi-Way 15 19th May 2006 04:15 PM
Page generated in 0.06602 seconds (71.88% PHP - 28.12% MySQL) with 10 queries
