#21 |
Did it Himself
You can only raise Qts, so the W3 with high Q already at 0.9+ means you will be limited to 1+ in a practical box.
Qts affects box size or VAS scaling factor. Lower Qts means a smaller box but at the expense of bass depth (-3dB point)
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#22 | |
#23 |
the B3 : Qts = 1.00, Vas=0.8L, Fs=105. On inspection Qtc will always be > 1, so you will get a peaking response. shown is 2dB peaking and 3dB peaking. However all is not what it appears, the B3 should not be used full range. If it is then at the input of the amplifier the input coupling capacitor should be reduced in value such that the response is -3dB at ~ 150Hz. So at least the response will be ~ flat. However as recommended by Zaph HT filtering should be used. |
#24 | ||
your sealed target for the W5 should be Qtc = 0.6 to 0.7, as size is the critical issue you should go for 0.7 = Vbox = ~ 3L. The F3 point of all the sealed alignments Q < 0.7 is ~ 100Hz. 3L may seem small, but if you want a bigger box, reflex it, this will also give you much bettter bass extension. With a Qts = ~ 0.4, a box that is ~ half Vas will always give Qtc = ~ 0.7. The F3 point of the B3 is somewhat illusory and also irrelevant as it should be used with bass filtering, if it isn't it will be boomy and run out of bass excursion capability if you even look at it. The F3 point for the B3 is lower than the 5" when they are both in 3L. This is generally expected. If two drivers are in the same box, then the driver with the lower efficiency will have more bass extension. As the B3 is 8dB less efficient the amount of extra bass is poor. But bass extension and bass loudness capability are completely different things, the 3" can't do bass, the 5" can, relatively speaking. quoting Zaph on the B3 : Quote:
#25 |
Wow, sreten ... that was some response
Let's summarize: - Dude! Distortion! Sure the low frequency's on the 3" are louder... cuz you are also getting a bunch of high frequencys in there too, in the form of 2nd and 3rd order harmonic distortion! Okay, again that makes total sense, and I almost feel bad for not reading Zaph's comments on this issue more carefully, but... hey... information overload. The subject is big! So, lets talk briefly about distortion. Zaph simply measured it directly (however you do that... I was just looking at the B3S on parts express and noticed: Frequency range: 300-15,000 That would make some sense, now that I see the distortion below 300! Interestingly, the B3N says... Frequency range: 100-7,000. I really, really, really doubt it. So maybe I simply can't know without measuring. Might be a lesson learned here that... "until you measure the speaker yourself (or have data from another trusted diy'er)... you don't know *anything* about the speaker". Okay, sounds like I really, need to buy a mic and mic pre-amp, and start learning to take measurements. Noodle_Snacks suggested these: mic: behringer ECM 8000 preamp:behringer UB802 Those the best cheap options? Thanks again, I have learned alot this week |
#26 | |
| How to calculate an enclosure with variovent ? | TomatoBangBang | Multi-Way | 4 | 16th January 2009 04:35 PM |
| How to calculate volume, F3 for 2 drivers? | ezkcdude | Subwoofers | 2 | 26th January 2006 07:41 PM |
| Newbie: how to calculate pot for volume control | wdekler | Solid State | 7 | 22nd March 2005 08:40 PM |
| how do I calculate the sub box enclosure? | Tony.ca | Multi-Way | 5 | 8th June 2003 12:05 AM |
| Calculate Volume for Triangular Prism..I think | Bose(o) | Multi-Way | 4 | 12th June 2002 12:55 AM |
| Page generated in 0.11292 seconds (80.73% PHP - 19.27% MySQL) with 11 queries |
