Scan Speak 15W8530K00
Does any body know a nice DIY speaker wich consist of a scan speak 15W8530K00.
I have a pair of these here at home ( new ) and i like to build a nice speaker.
Options for now:
- http://www.troelsgravesen.dk/Ellam.htm
- http://www.troelsgravesen.dk/W1501_95.htm
- http://www.troelsgravesen.dk/W1500_97.htm
the last one will be my favorite becouse i know the tweeter from my previous speaker/speaker that i have now -> eVe II
I built it first with the 9700 tweeter, later with the 7000 tweeter :)
So who has more (proto) type of speakers with a pair of 15W8530K00
URL + PICS are welcome
Have a look at these.
I've paired my ScanSpeak 15W/8530K01 drivers with Heil AMT tweeters. The box is 35x34x20cm, with a volume of 15 litres. Just love the sound - very natural, balanced, accurate... I'm driving the speakers with a DIY tubeamp.
You may check the speakers out at my website:http://www.moxtone.com/moloh.htm
Milan
P.S. The tubeamp project is underway under the Siemox F2a heading.
Joined 2002
Hi:
The box is made of 19 mm thick MDF boards, which are glued together at the edges using wood glue. The box was first treated with some car-repair putty, then sanded with sandpaper and sprayed over with a black acrylic car finish. When the paint was dry, I applied a single coat of clear laquer for protection. The front is angled at 10 degrees.
I bought the tweeters off of eBay for around 150 USD/pair. The front grill shown in the picture cannot be removed although I believe there are some models of these particular tweeters where the (silver plastic) grill comes off (10B model or similar).
I hope this helps.
Milan
