Old 1st May 2006, 03:57 AM   #1
lndm is offline lndm  Australia
Default Horns, bends and upper mids
I want to design a front horn that extends from bass to a couple of kHz. The thing is, I don't want to have to buy the block next door.
Can I implement a slow 180 degree crescent and retain the mids? I want to design so the horn's top end rolls off my driver in lieu of a crossover so I would like to have a little predictability.
It won't need to be perfect, I am (maybe wrongly) thinking you'll need to be able to 'see' the cone when putting mids through a front horn.
Old 1st May 2006, 01:23 PM   #2
el`Ol is offline el`Ol  Germany
When you load the PM250 in the bass you have 100dB and a nice rolloff. I am no expert, but I never heard about anybody who has successfully designed a widerange horn.
http://www.ciare.com/pdf/catalogo/PM250.pdf
Old 1st May 2006, 04:54 PM   #3
palesha is offline palesha  India
There r hardly any drivers covering good low bass & good mid upto few kiloherts. U can get horn from 300~400 hz to 2 kiloherts. Then u must hv sub & high frequency drivers seperately for u.
Old 1st May 2006, 10:22 PM   #4
What parameters indicate bandwidth in a driver for this purpose?
My drivers exhibit low mass rolloff according to Dr. Bruce Edgar's formulas, but a midrange horn seems to be possible all the same.
I have simulated what I want in Hornresp, nothing there (that I can see) suggests it will not work.
Help me taming the upper mids of LM3886 chipamp Edits Chip Amps 76 18th May 2008 12:25 AM
Using Thiele Small to estimate *upper bandwidth of woofers & mids rick57 Multi-Way 13 24th August 2006 06:13 AM
Seas Excel mids vs. dayton rs mids in dipole sqlkev Multi-Way 2 10th July 2006 06:28 PM
Modelling the reflection in TL bends Onur Multi-Way 6 29th October 2005 08:01 PM
Calculating bends in a tapered TL bwbass Multi-Way 12 5th February 2005 08:58 PM
Page generated in 0.07183 seconds (67.30% PHP - 32.70% MySQL) with 10 queries
