Old 30th April 2006, 05:49 PM   #1
Default Jamo Surround 200 Speaker Damage
I know almost nothing about speaker design. I have damaged a 4" cone in a Jamo Surround 200 Speaker. Can I replace this with another generic cone or are there things I need to look out for. I'm thinking that at least I need to match the change in the other speaker.
appreciate any help
Old 1st May 2006, 12:56 AM   #2
David Gatti's Avatar
Do you have a picture of the driver?
Old 2nd May 2006, 06:30 AM   #3
This is it. The centre is dented in but not torn. The cone is torn along its outer rim for about 120 degrees
Old 2nd May 2006, 07:30 AM   #4
Firstly, I would try repairing the cone - PVA glue on the surround, and pull out the dustcap with a vacuum cleaner,pin, or adhesive tape.
If that fails, then look at replacement drivers - generic paper cones of the same diameter might suffice but you won't be sure until you try it.
You might also want to pull the driver out & look on the back for any clues as to it's brand, size, model number and impedance, and whether the driver is shielded.
Here's some possible replacements:
http://www.partsexpress.com/webpage....ctGroup_ID=573
This may be the best candidate:
http://www.partsexpress.com/pe/showd...number=290-370
Old 2nd May 2006, 03:05 PM   #5
Thanks a lot for the tips. I'll try a repair job. There are no helpful marlings on the back of the driver.
DIY Surround speaker : please help cmsajith Multi-Way 11 3rd November 2008 09:54 PM
speaker or crossover damage evlah Multi-Way 9 19th March 2008 03:49 PM
Surround speaker advice/links Grahamt Multi-Way 4 17th November 2005 03:47 PM
can this amp damage the speaker? ksl Multi-Way 5 5th June 2003 04:53 PM
Types of speaker damage,and how to avoid them Bull Multi-Way 18 21st January 2003 10:14 PM
Page generated in 0.08029 seconds (74.20% PHP - 25.80% MySQL) with 11 queries
