Hi, does anyone knows how to measure the response of a woofer bigger than 20 cm until 500Hz ?
In fact, as we know, the near field response is valid until the frequency Fmax = 10950/D where D is the baffle dimension in cm So, the measurement of a 20 cm driver is valid (in near field) until the frequency Fmax=10950/20=548Hz but what about a driver larger than 20 cm ? For example, a driver of 30cm is valid until 10950/30=365Hz !!! I saw that farfield measurement is not valid under 500Hz in a non-anechoic chamber, so how about measuring the gap between (es.) 365 Hz and 500 Hz ? |
#2 |
I've found measuring ground plane style works - Place the speaker on the ground away from any walls, boundaries etc. Place the mic 2m away from the baffle (on the floor), and measure. Here's a measurement of my Beyma LX60 15" driver in a sealed box, designed to be F3 at 80Hz. Below is Beyma's response chart for it. quite similar. Rob. |
#3 |
A woofer in a closed box or a vented box can also be measure inside the box, up to the first standing wave inside the box. I don't know if this helps as the upper limiting frequency is not necessarily higher than with the other method. Anyway, I think the inside-the-box method is kind of cool. You will have to tilt the response by 12 dB/octave, though.
#4 |
First of all, thanks for your reply
Is this measurement a sum of NF+FF ? Or it's only a FF ? Thanks Bye |
#5 |
The idea behind the measurement is that if you measure a speaker in half space (on the ground with no other boundaries) at 2m , it will be the same as measuring the speaker at 1m in full space (4pi)
Do a search on 'ground plane' Rob. The top plot is exactly as I stated, measured at 2m from the baffle, mic on the floor, speaker on the floor, no other boundaries. |
#6 |
Hum ...
OK I understand now, but I know that the measurement in half space should be reduced of 6dB to compensate the half space effect. However I'll do a research about ground plane Bye |
#7 |
I saw the ground plane measurements and they are quite interesting, but now I've a question for you:
in these measurements the microphone is placed attached on the floor and I think it's good for lowest frequencies, but what about measuring a tweeter or a midrange (for upper frequencies) ? I mean, tweeters are quite directionals aren't they ? Should the microphone be placed a bit detached from the floor and in axis with the tweeter's center ? |
#8 |
'Testing Loudspeakers' by Joe d'apollito will answer all your questions and more, better than what I can.
http://www.audioxpress.com/bksprods/bkindexltheory.htm I have the book, it's full of good info. Cheers, Rob. |
#9 |
hi Rob just send a PM to you
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!.. |
#10 |
Sorry for unpolite OT.
Rob, will you be so kind and share a measuremets of Beyma 15LX60 with me, perhaps via e-mail. I'm interested in raw driver impedance plot, but any other (T-S, distortion etc.) wouldn't hurt. Thanks in advance. I'm in "consideration phase" and closer info than producer's DS will help. |
| FS: Large inductors, Large Ports, and Leaky Holes | luvdunhill | Swap Meet | 10 | 6th March 2009 03:01 PM |
| Does anyone have nearfield measurements of an Eminence Alpha 15A? | Saurav | Multi-Way | 8 | 19th June 2008 11:45 PM |
| WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) | gtforme00 | Swap Meet | 9 | 3rd June 2008 09:57 PM |
| Large Woofers! | Tenson | Multi-Way | 34 | 23rd April 2006 09:24 PM |
| FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers | cm7 | Swap Meet | 0 | 1st August 2003 01:59 PM |
| Page generated in 0.11581 seconds (75.74% PHP - 24.26% MySQL) with 11 queries |
