Could someone tell me please the formula for helmholtz resonance of a small chamber with opening as is used on a couple of TL enclosures to remove higher resonances either from speaker or line harmonics.
How do you size the chamber? Can a small chamber off a port be used to remove or lower the level of the harmonics in a BR port? jamikl |
#2 |
I think you might be interested in looking at Martin J King's page, the Mass Loaded Transmission Line enclosure.
http://www.quarter-wave.com/Projects.html It is a sort of enclosure which is tall and skinny, uses both quarter wave and bass reflex principles, and eliminates the upper resonances of the Transmission Line.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
| Air Resonance | davidross | Full Range | 15 | 17th April 2009 09:10 PM |
| OpAmp Resonance? | Stew | Digital Source | 32 | 7th April 2007 07:59 PM |
| Resonance Frequency | DR ANALOGUE | Multi-Way | 5 | 11th January 2006 07:49 AM |
| tonearm resonance | Werner Rem | Analogue Source | 4 | 6th February 2005 09:12 PM |
| Crossover too near resonance? | niacin | Multi-Way | 16 | 15th April 2004 03:32 AM |
| Page generated in 0.33620 seconds (15.47% PHP - 84.53% MySQL) with 10 queries |
