Old 28th April 2006, 08:56 PM   #1
Default Drviers for SMALL speakers
I'd need to know some woofers that would be good for 6L speakers and that would still give sound under 100Hz in a small box like this. Just have to build a small fast & easy project and I have around 3 weeks.
Antoine
http://dmsaudio.ca/
Old 28th April 2006, 09:44 PM   #2
You need to be more specific there's like a 1000 drivers that could fit that profile.
Old 28th April 2006, 09:48 PM   #3
Cheap?
I don't need a lot of power also.
Should be available @ Solen or Madisound if possible. (Solen is 5 mins in car away)
Antoine
http://dmsaudio.ca/
Old 29th April 2006, 02:25 AM   #4
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
Go to:
http://www.partsexpress.com/resource.../sb_guide.html
Click on the "Vented Volume cu.ft." header, look at teh speakers in the 0.2 cu. ft range...
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Old 29th April 2006, 12:44 PM   #5
Thanks for the link!
I found the Hi-Vi M4N on PartsExpress and I then found the B4N that would suite better for my boxes at Solen. Now I wonder if they have it in stock or it's an order.
Now I need a tweeter... The thing goes up to 3kHz.
Antoine
http://dmsaudio.ca/
Old 29th April 2006, 02:07 PM   #6
Oh, and I'm not too sure but would plywood be OK in this case?
Antoine
http://dmsaudio.ca/
Old 29th April 2006, 02:14 PM   #7
3/4" plywood should be fine. More internal bracing the better though.
Audio DIY Page
Old 29th April 2006, 02:51 PM   #8
OK. Gotta build the boxes this weekend...
The holes can wait I think, I don't know which tweeter could match with it.
I also have no real idea about the XOver...
Antoine
http://dmsaudio.ca/
Old 29th April 2006, 02:57 PM   #9
problem solved, I think
http://www.partsexpress.com/projects...ivijuniors.pdf
Antoine
http://dmsaudio.ca/
Old 29th April 2006, 04:30 PM   #10
inrank is offline inrank  United Kingdom
inrank's Avatar
what about the Css Fr125S?
small, good bass and full range.
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 07:54 PM
new speakers for mains in small HT jaygeorge1979 Multi-Way 3 3rd November 2007 03:35 PM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 01:19 PM
(very) small speakers... ALFIrE Multi-Way 11 1st July 2004 01:44 PM
Best small speakers sparkle Multi-Way 10 27th May 2004 11:37 AM
Page generated in 0.08960 seconds (78.23% PHP - 21.77% MySQL) with 10 queries
