Old 27th April 2006, 12:27 PM   #1
inrank is offline inrank  United Kingdom
inrank's Avatar
Default FR125s + Bass
hi, here are my new Fr125S's in a 11.5 L sealed enclosure ....
i did want to build a new horn/tl enclosure for them, but they dont quite work the best so...
i could make a bass enclosure for ..
--one 8 Ohm 6 1/2" bass driver (on front)--
--two 4 Ohm 6 1/2 Bass drivers in paralel(on front)--
--one 8 Ohm 8" Bass driver (on the side)--
(could add a Passive Radiator aswell)
using the same width and depth of my standmounter and around 600mm tall. (it would be 20L in volume)
creating a 2 or 2.5 way with two enclosures with the FR125 crossing at around 80-100Hz
looking for mabye £40ish each for drivers (or £30 for the 4Ohm ones)
example....
What would be best (configuration and driver)????
Old 27th April 2006, 01:10 PM   #2
Default Re: FR125s + Bass
don't quite understand, for a 0.5 way c/o frequency is ~ 300Hz,
you can't have a 0.5 way below 100Hz - unless you are actually
using a 0.5 way to partially compensate for bass unit roll-off.
Presume you mean in series ?
Having them either side in force cancellation mode is an idea.
/sreten.
Old 27th April 2006, 01:12 PM   #3
inrank's Avatar
sorry, yes i ment in series.
all i want is for 1 or 2 bass drivers to take over from the Fr125s at around 80-100Hz, or whatevers best
Old 27th April 2006, 04:53 PM   #4
Crossing over around 100Hz is problematical unless you go active.
If you go active (i.e. bi-amping) driver choice is much more open.
/sreten.
Old 27th April 2006, 04:54 PM   #5
inrank's Avatar
well i was planning on making a gainclone in the summer for the fr125s's anyway so i could make two...
Fr125s Bib cangaceiro99 Full Range 16 26th August 2008 06:16 AM
My take on FR125S in OB Rafal Full Range 37 22nd March 2008 10:20 PM
FR125S x2 (EU,UK) jimbo1968 Swap Meet 0 23rd November 2006 05:21 PM
css fr125s joe perry Full Range 5 10th May 2006 04:11 PM
FR125S in TL? robertG Full Range 37 27th March 2006 03:58 PM
Page generated in 0.07959 seconds (71.99% PHP - 28.01% MySQL) with 10 queries
