Old 26th April 2006, 10:51 AM   #1
Gold_xyz's Avatar
Default Speaker 8" replace
Hello !
In many small guitar-amplifiers has a 8 inches loudspeaker :
Peavey Blazer 158
Marshall MG15 CD/CDR/CDX
Fender Frontman 15 G/R
and many other....
The original loudspeaker have a good quality but if i will
a best quality speaker i have a very little choice.
The typical speaker climbed on on these amps is of this type:
Imp. : 4 or 8 Ohms
Diameter : 8 inch (20 mm)
Voice coil : 1 inch (25 mm)
Basket : pressed steel
Cone : paper
Cone surround : paper or treated paper
Magnet : ferrite 3.3 inch (86 mm)
total weight : 2.2 lb (1 Kg)
my desire would be to replace with a loudspeaker so built
Voice coil : 1.5 inch (38 mm)
Cone surround : treated cloth ..
I have found only these (but only 4 Ohms type)
--- to be continued --- (telephone acc. )
Old 26th April 2006, 11:55 AM   #2
Gold_xyz's Avatar
I have found only these :
http://www.sica.it/index.htm
*steel basket - ferrite magnet* Type Z004640 4 Ohms
and *dual cone * Type Z004670 4 Ohms
but 8 Ohms version doesn't exist...
The long and the short of it is that for replace a 12" or 10"
inches speakers i have a lot of choice but for 8" nothing !
every suggestion is always welcome !
bye
P.S. sorry for my terrific english ...
Old 26th April 2006, 12:51 PM   #3
http://editweb.iglou.com/eminence/em...ers/alpha8.htm
http://professional.celestion.com/gu...spec.asp?ID=13
/sreten.
Old 14th January 2010, 10:21 AM   #4
Default Super 8
Celestion | Guitar Loudspeakers
Old 14th January 2010, 10:22 AM   #5
Need to replace Tempest with possibly 2 15" Dayton RS HF JeffKnob Subwoofers 3 13th August 2007 07:43 PM
ANY "High-Perf" SIL op-amps to replace NJM5532 homemade Parts 2 13th December 2006 03:41 AM
Crisis! need to replace 15" driver - Gig tomorrow!! Pbassred Multi-Way 3 21st March 2005 06:20 AM
replace Focal 8" woofer? dreamer Multi-Way 4 6th September 2004 08:09 PM
can't "edit", ie replace .gif file jcx Forum Problems 1 4th March 2003 11:55 PM
Page generated in 0.10835 seconds (62.28% PHP - 37.72% MySQL) with 10 queries
