Hi everyone! I hope this is the forum I needed to come to get the right answers, from what I've read so far, you guys seem very knowledgable!
So, I bought a home theather set a few years ago. I invested quite a large sum and so far I've been very pleased with the output. But now, I'm working on my new home and I won't be able to fit my corner (5.1 system) speakers into the living room design. My front speaker each have the woofer coming out on the side of the enclosure and I need to insert it into a wall to wall library (which will be custom made so I can use whatever space I need). So I already have all the hardware that I wish to reuse and would only need to build a new enclosure with all drivers coming out the front. My rear speakers are in the same boat. The woofers coming out on the side. The difference is that I need to fit these in the ceiling so I'm a bit more constrained. The width must not exceed 12" and depth can't be more than ~10" which imo shouldn't be a problem. If need be, I can take pictures of my speakers so you can get a better idea of what I'm speaking of. Unfortunatly, I've never built speakers before and only starting to inform myself. On the bright side, I already have everything except the enclosure which I hope is the easy part. My brother says I should sell the ones I have and buy new ones that would fit but I ain't that kind of guy. Heck, I'm building a DIY projector for my new home so I'm not afraid to work with my hands and learn new things. I hope you guys can help a newbie like myself get just the right sound out of the speakers I already have. |
#2 |
Welcome Lohkay,
Try posting pics., they speak louder than words. I understand that you're going to rebuild the cabinets, perhaps you could just re-orient the cabinet with the woofer facing into the room and try fixing the smaller drivers on the same baffle; but you may have to live with the ugly wires coming out from one side and to plug the holes(of the earlier speaker cutouts) on the opposite side. In case you build a totally new cabinet, maintain the enclosure(inner) volume as same as the old box. |
#3 |
Thats a pretty good idea... didn't think of that! Only problem is the current depth is over a foot which would make for some very large speakers.
I'll try to get a hold of a camera and post some pics. In the meantime, keep the info coming! As in: what kind of wood works? If I need a specific type of wood, why? you mentioned I need the same volume, why? I saw how my speaker enclosure were made and I remember seeing them cutting grooves in a large panel so they could fold it into the final shape... any reason for this? Can I use seperatly cut panels or do I need to do the same? Thx!
#4 |
Lohkay,
"About a foot" doesn't seem so wide whereas "over a foot" can mean much more, anyway what is the woofer size(diameter). What are the dimensions of the enclosure? With regard to your questions, you need to replicate the original enclosure which was designed for the woofer; am I right or do you intend to tweak/better the performance. If you're satisfied with the sound now, it is preferable to make an identical size box. Why?, it is a little long story to attend to in one post. Read the threads in this forum and also some books like 'Loudspeaker Cookbook' by Vance Dickason for example. Wood is not what you need, it's either MDF or Plywood which are acoustically more dead to resonances than wood. By the way, I couldn't figure out the part about grooves...., (were the speakers not factory made) maybe if we can get to see the shape of your existing enclosure, then some of the others could chime in. Regards, Francis |
#5 |
#6 |
Nails are not recommended, will come loose after a while.
Screws are okay but may not look nice. Glue is better, yes you can cut the boards to size and glue them. After the gluing is well cured, you may have to plane/level out the rough edges. Happy DIYing |
#7 |
| car speakers for the home | audiotang | Full Range | 9 | 6th March 2012 04:37 PM |
| Home speakers with DLS. | javiertoti | Multi-Way | 3 | 21st January 2009 01:11 PM |
| Car speakers in the home??! | bleachershane | Multi-Way | 16 | 26th November 2008 04:58 AM |
| Car speakers for home use? | Matt3141 | Multi-Way | 5 | 16th January 2007 07:56 PM |
| fs: speakers, car and home | Stuart Easson | Swap Meet | 10 | 12th July 2006 05:00 PM |
| Page generated in 0.10578 seconds (77.58% PHP - 22.42% MySQL) with 10 queries |
