Old 23rd April 2006, 06:57 AM   #1
ostie01 is offline ostie01  Canada
Default Measuring speaker after they are built
Hi, just would like to know which method you use to calibrate or fine tune your bass reflex speaker after they are built.There's lot of information before the building but when the project is finish,not much. How can I be sure if all the math I've done before will be the best for the finish product.Is it better to cut bellow, equal or above FS.What is the best way to be sure that the vent is cut to the right lenght or is too long or too short other than my ears.Thanks
Old 23rd April 2006, 08:57 AM   #2
e-side is offline e-side  Netherlands
This can be done by measuring the impedance of the system. In case of a Bass-Reflex enclosure, at the system's resonant frequency (Fb) impedance should be at a minimum level. When your measured resonant frequency's near the predicted/calculated Fb, then you built your design as intended.
See this site for the procedure for impedance measurements. No cross-over should be connected when measuring.
Old 23rd April 2006, 04:05 PM   #3
don't forget to measure the THD too
Old 23rd April 2006, 04:38 PM   #4
claudio is offline claudio  Italy
claudio's Avatar
in my home page is illustrated how to measure the finished speaker, and how to check its resonance frequency as well as other things, through the impedance response.
I hope it helps.
Claudio
Speaker for Mic Measuring Marik Full Range 10 25th February 2009 05:06 AM
measuring speaker impedance dallaire Multi-Way 4 11th December 2007 10:44 AM
I need to built microphone for measuring? Igor1920 Multi-Way 1 5th September 2005 06:49 PM
Measuring TSP of a DVC speaker e-side Multi-Way 2 7th July 2005 04:53 PM
Page generated in 0.08334 seconds (71.73% PHP - 28.27% MySQL) with 10 queries
