karma line arrays
karma line arrays
Old 22nd April 2006, 04:12 PM   #21
karma is offline karma  Canada
karma's Avatar
well got the drivers in and wired them up wow talk about dynamic
the sound is amazing and thats only one side
http://www.karmaelectronics.org
Old 22nd April 2006, 04:14 PM   #22
karma's Avatar
cheers
Old 22nd April 2006, 10:36 PM   #23
LineSource is offline LineSource  United States
LineSource's Avatar
Default Stuffing.....Diffraction.....Baffle Step
Karma,
Some cabinet stuffing often helps the midrange by removing reflections from the rear cone. I like using Corning 705, similar to ceiling tile material.
Simulations of line arrays and line sources shows a much smoother SPL curve with ~ 4" radius sides. There are free programs at FRD Consortiumthe you can try out.
http://www.pvconsultants.com/audio/frdgroup.htm
Less baffle step compensation seems necessary for line arrays than single drivers, so some experimentation may be necessary.
Old 23rd April 2006, 01:32 AM   #24
bickeler is offline bickeler  United States
Kool nice job on that one.Hey are those posts dry?I'd assume you know this but I ask cause if they are you might point that out to the less knowledgable before they run to their local depot. Cause if they were not they'd probably twist into a pretzel or crack in short time.Some might think it's like plywood just take home and cut and glue hehe.
Old 23rd April 2006, 01:49 AM   #25
karma's Avatar
its a 4x4 post and its dry so i dont think it will twist if it stays dry.
if it does twist it was a bad idea,i like to try new things that no one has tryed.
we shall see.
i didnt just go out and buy the wood its been siting in the sun for a year covered
Old 23rd April 2006, 01:50 AM   #26
karma's Avatar
Default Re: Stuffing.....Diffraction.....Baffle Step
Originally posted by LineSource
Karma,
thanks for the link, and yes thay will need some cabinet stuffing
Old 23rd April 2006, 01:53 AM   #27
chipco3434 is offline chipco3434  United States
Mr. Karma said:
That's the **** I'm talkin' 'bout.
Sell the point source speakers.
It will be hard to go back.
Old 23rd April 2006, 02:10 AM   #28
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Hey looking good. Those are tall eh.!
Old 23rd April 2006, 02:21 AM   #29
karma's Avatar
not bad
just working out on paper a sub for the bottom and brackets to hold the Ribbon Tweeters.
Old 23rd April 2006, 02:29 AM   #30
Banned
Originally posted by karma
not bad
Just working out on paper a sub for the bottom and brackets to hold the Ribbon Tweeters.
Where are the ribbon tweets ? What amp is powering these ?
karma line arraysHide this!Advertise here!
NSB line arrays for PA use? Spasticteapot PA Systems 1 1st April 2007 12:32 PM
Do line arrays... LizardBrain Full Range 4 23rd March 2006 05:21 AM
Line Arrays Down Under deaf monkey Multi-Way 0 14th December 2004 06:03 PM
Power for Line Arrays ralph-bway Multi-Way 4 27th February 2004 06:20 AM
Line Arrays Won Multi-Way 33 10th February 2002 10:20 PM
