Old 22nd April 2006, 01:20 AM   #1
Banned
Default Wwwtttwww? Wwtttwwww? Wtwwtwwtw?
make any sense?
I have 6 woofers, and three tweeters going into my tower speakers.
I'm wondering what configuration would be the best option?
thankyou for any input, I'll be sure to post pics when they are done
Old 22nd April 2006, 01:43 AM   #2
Hey Welcome to the forum! There is lots of information here. As far as your wwwTTTwww question i see a few flaws. One is (and correct me if i'm wrong) but putting 3 tweeters inline with each other seems like a bad idea it would greatly reduce vertical dispersion. And 'd figure they'red be some lobing issues.? Someone else should chime in as i'm still learning many concepts.
Old 22nd April 2006, 04:51 AM   #3
edjosh23's Avatar
angsuman,
You are correct. There would be comb filter/ lobing problems.
WhatsAWoofer?,
There are lots of options for you, but I also have a few suggestions. First off you need to read the line array white paper. Also, what drivers fo you have? I would not suggest more than putting 1 tweeter in front unless you are planning on a bessel array. There are line arrays that have multiple tweeters that are not in a bessel array, but I personally am not a big fan. If you want to try and use all of your drivers you can place one tweeter in the front and one in the back, but I don't think a 3rd tweeter needs to be used. You can easily place 6 woofers in a line array, there are many arangements to try. I have contemplated a line array with 4 woofers, 3 in front in an mtmm fasion with 1 in the rear, haven't done much research though. There are many line array fanatics on the forum that are much more knowledgable, but hopefully this is a good start.
Josh
Old 22nd April 2006, 09:14 AM   #4
Banned
maybe I'll just do whatever the hell I feel like, they'll probably sound **** anyway.
Old 22nd April 2006, 02:42 PM   #5
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Listen to the advice that has been given and then do some research. When that's done, research some more as you will end up with a better speaker.
3 tweeters are not the go.
No longer DIY active
Old 22nd April 2006, 03:54 PM   #6
quiet is offline quiet  United States
3 woofers in front
3 woofers in rear
1 tweeter on the front / rear / and the last on the top...
why not?
they'll look mean
i like the doing what ever you want part (your gear)
i think some people are scared to try things that others have done...
what sounds like *** to some may be honey to others
HAVE FUN
- W W T W T W T W W
Old 22nd April 2006, 04:24 PM   #7
Banned
I'm not really one for sound quality.
I just need a decent system, that will keep up with my subwoofers 125+ dBs from 30 - 80Hz...
Old 23rd April 2006, 08:30 PM   #8
Banned
I rearranged my room a few days ago.
subs in the same position, but the listening position has changed, and now the bass is rather weak.
sucks doesn't it?
anyway, truth be told, I have 12 cheap tweeters on the way already cost about $US2.90 each, so, I'm not really worried if they sound crap.
Small horn Tweeter. 3000 - 22,000 hz. 8 ohms.
and the woofers, are some "cheap" 6inches, that I got off ebay for a good price:
Old 24th April 2006, 12:37 AM   #9
Looks more like the making of an array.That's a lot of drivers to put in a pair of boxes array would be sweet though I think you might go deaf though with 12 horn tweeters full blast!
Old 24th April 2006, 02:33 AM   #10
Relax is offline Relax  United States
Make two towers:
W
W
W
WT
WT
W
W
W
Or maybe 4:
W
W
T
W
W
Page generated in 0.12363 seconds (79.85% PHP - 20.15% MySQL) with 10 queries
