Old 22nd April 2006, 12:09 AM   #1
Default Angled Center Channel?
I'm in the final stages of a center Channel I'm building.
Uses 2 Vifa TC11MG-07 and two Linaeum ribbons.(Yes the omni directional Shack ones.)The speaker will be sitting ontop of a 46" projection Tv that is rather high(5 ft easy)as there is no other place.
I was wondering instead of putting on the flat sides should I make an angled design where say the speaker is at maybe 10-45 deg angle?
I couldn't see the Linaeums being a big issue with this or would they?But I'd think the mids would.Any thoughts on this?
Old 22nd April 2006, 04:09 PM   #2
edjosh23's Avatar
I'm not exactly sure I understand your design, but angled center channels are a good idea. Just be sure to do the proper calculations and you will be very happy to end with a center channel that you listen to on axis.
Good Luck,
Josh
Old 22nd April 2006, 10:12 PM   #3
This is what I'm talking about in the drawing(If you can call it that.)An TTMM Linaeums are stacked one on the other.
Old 22nd April 2006, 10:29 PM   #4
Here's a pic.(Perhaps the worst picture you've ever seen as well.Only cam I have right now is a CleverCam!As seen on TV!)
Old 23rd April 2006, 01:43 AM   #5
Hmm I've been listening to this all day and I think (Not to toot my own horn as it were)this is a very intelligble center..Sounds really clear and dialouge is crystal.
I think these Linaeums stacked one on the other work pretty well.Anyone ever stack the dipole Linaeums and do some measurements?Or even side by side?
One reason for the stack is one is just not enough(82db sensitivity?I think) to match the 2 VIfa mids.I've had the Linaeums for years never used them cause no matter the driver they sounded a bit anemic.
Need center channel help Ryan_Mc Multi-Way 0 12th February 2009 03:36 AM
Center channel with one mid Buzzy Multi-Way 11 17th October 2008 03:52 PM
Center channel 66Panel Multi-Way 0 25th August 2008 03:48 AM
Center channel using TB flaevor Multi-Way 2 3rd May 2005 08:27 PM
Center Channel wigginjs Multi-Way 6 26th October 2004 01:48 PM
Page generated in 0.09050 seconds (73.61% PHP - 26.39% MySQL) with 11 queries
