tweeter help
tweeter help
Old 21st April 2006, 05:44 PM   #1
ally_n_2000 is offline ally_n_2000  United Kingdom
Default tweeter help
Hi
I'm just after everybodys opinion about tweeter selection. can someone please explain which specifications should be used to decide. Ive been using Sensitivity, Impededance, freq range but not too sure why, what are good figures?
Seas 27TBFC/G and Peerless 811830, both have 92 dB SPL, 1.5kHz - 20kHz but one with 6 ohms and one with 8 ohms.
Which would you choice.
Old 21st April 2006, 05:48 PM   #2
R.I.P.
http://www.zaphaudio.com/tweetermishmash/
Is as good a place as you can find.
Generally would take Seas over Peerless tweeters nearly all the time.
/sreten.
Old 22nd April 2006, 10:14 AM   #3
Yeah i have taken a look on that site, it is a goo reference but don't really want to base my choice on one review.
Anyone got ideas?
Old 22nd April 2006, 04:12 PM   #4
lndm is offline lndm  Australia
These parameters sometimes imply things about the quality of tweeters, but you can't just judge a tweeter based on them.
You might choose one with a sensitivity to match your mid/woofer (or slightly higher). You might choose one with an fs a couple of octaves below your desired crossover point. etc.
Other than matching specs and measurements to your needs, your next best resource might be sites like zaph's. Listening tests are sometimes the best way to do it.
Old 23rd April 2006, 07:06 AM   #5
angsuman is offline angsuman  United States
Well first depending on your application you might need a certain impedence or sensitivty etc. Once you have that down figure out how low you want to cross over and then find the remaining ones that would fit your choice. Sites like Zaph's and Mark K's are great because they have distortion curves which manufacturers almost never publish. If you know how to properly interpret these curves you can end up picking an excellent tweeter. However everything is application dependent.
tweeter helpHide this!Advertise here!
Why not a ribbon tweeter instead of a horn tweeter? Curly Woods Full Range 9 15th July 2009 05:09 PM
Tweeter help for Miller & Kreisell Tweeter 17500 merajsalek Multi-Way 4 3rd September 2008 04:41 AM
Linaeum Dipole Tweeter as a Super tweeter? ktuuri Planars & Exotics 5 17th June 2008 07:52 PM
Round radiating tweeter, aka "Enterprise 1" tweeter! tubee Multi-Way 39 13th May 2007 10:03 AM
Titanium tweeter vs Ribbon tweeter goldyrathore Multi-Way 14 17th May 2004 08:21 PM
