Old 21st April 2006, 12:51 PM   #1
Default Silly question about loudspeakers and crossover
Greetings,
I have this silly question:
If you have a complete loudspeaker that includes passive crossovers and drivers. And suddenly you remove either the tweeter or one of the woofers, the crossover behaviour will change? If it doesn't change the other components (tweeter and woofers) left on cabinet will continue working as before? Apart from the extra big holes in the cabinet...
Thanks,
Mike
Old 21st April 2006, 01:16 PM   #2
Did it Himself
richie00boy's Avatar
Removing one driver should not affect the other, as long as parallel crossovers are used. Which they are in 99.9% of cases.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 21st April 2006, 01:29 PM   #3
So I will have to check the crossover to be 100% sure eh?
If they are parallel as it seems to be , removing a driver and letting the other two (2.5 way 3 driver design), won't allow more wattage for the other two than usual?
Thanks for the help
Old 21st April 2006, 01:29 PM   #4
lndm is offline lndm  Australia
Better to plug those holes I'd reckon.
Old 21st April 2006, 01:31 PM   #5
Of course! I don't care about the sound right now... I want to play around being reassured that the drives are perfectly safe
Old 21st April 2006, 01:35 PM   #6
Did it Himself
Being in parallel basically isolates the HF and LF sections, so play at will
Old 22nd April 2006, 08:55 PM   #7
Svante is offline Svante  Sweden
Svante's Avatar
Also... If the tweeter has a 2nd order filter, you will be left with a cap and a coil in series, without the tweeter. That can give a pretty deep impedance dip, where the impedance at the dip is the DC resistance of the coil (typically 0.5 ohms ?). That could be bad for the amplifier, either by blowing it (but I don't think so) or by making it generate distortion.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
A silly question, but I'm going to ask anyway :-/ TurboFC3S Multi-Way 19 1st April 2009 02:01 AM
Silly Question about 807 7N7 Tubes / Valves 2 17th November 2007 11:14 PM
Silly Question???? Zero Cool Solid State 7 16th October 2004 11:34 AM
A silly question, but... mjarve Solid State 2 3rd August 2004 09:50 PM
Silly question Lisandro_P Everything Else 2 11th May 2002 07:27 PM
Page generated in 0.07214 seconds (84.02% PHP - 15.98% MySQL) with 10 queries
