Hi Guys,
Trying to find an appropriate crossover for this coaxial speaker. Tried contacting the dealer & manufacturer for the recommended crossover but so far no response. Any help advice would be great. Thanks |
#2 |
I don't want to be silly but my first reaction is that if it is a co-ax the cross over is probably intergral with the unit. For a start can you tell us how many ternimals does the speaker have? If its only a pair. i.e. one positive and one negative then that suggests there is an internal cross over. Put up the manufacture's name might help and post when people in that part of the world are surfing.
If it does need an external xover then the specs suggest a shelving network is needed to drop the tweeter down to the level of the woofer and then something around 2kilo heretz would look promising.
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse. |
#3 |
Hey jonathan,
The speaker is P Audio. - BM-10CXA http://www.paacoustic.com/Product_De...uctID=BM-10CXA As far as i know the crossover is not intergral. From the pic you can see the 2 terminals for the woofer and the two terminals for the hf unit are at the base. Thanks. |
#4 |
Hi, I think you will have to experiment a bit here
If you do as Jonathan suggested - to cut midrange at 2Khz with a single coil - you will probably get a delayed reaction because of following peak, and afterwords get a little higher suiteable crossoverpint - then simly find a condensator to match - a simle case of "try and error" I have been interested in this thing too, so let us know how it goes further. |
| Need a cross ref # | clayton | Car Audio | 2 | 27th November 2007 01:00 PM |
| How to cross over | Learnincurve | Subwoofers | 7 | 30th January 2005 06:42 PM |
| No Cross Over! | chris ma | Multi-Way | 27 | 3rd January 2003 01:53 AM |
| What do you get when you cross... | nobody special | Pass Labs | 13 | 12th October 2002 05:47 PM |
| Tube cross selection | AuroraB | Tubes / Valves | 1 | 8th March 2002 07:40 PM |
| Page generated in 0.06396 seconds (81.48% PHP - 18.52% MySQL) with 11 queries |
