I've looked for it everywhere, but i'm curious what defines the acoustic center for a driver with a phase plug? Not that i'm seeking time-alignment in a future design, but i'm curious if the acoustic center is always located at the voicecoil or if its at other parts. For example in a dome tweeter is the acoustic center at the voice coil edges or at the tip or the dome. Same question for a phase plug? Is the end of the phase plug considered the acoustic center of a driver.
#2 | |
Hear the real thing! |
#3 |
I usually approximate the acoustic centre as the point at which the voicecoil former attaches to the diaphram, whether it's a cone with/without a phase plug, or dome.
This seem to be a pretty accurate estimate in my subsequent measurements. Some say it's slightly forward of this point which may be the case but it depends on diaphragm material, cone geometry etc. |
#4 |
Oh so a phase plug doesn't have an affect on where the acoustic center is? So generally its at the former to cone joint?
#5 |
IIRC Dickason says that it is nominally at the air gap, and my measurements of mid and tweets confirmed that. (Although it's so close to the former/cone joint that the difference is probably not usually a matter of concern. )
#6 |
Just a shot in the dark here, but doesn't the phase plug reduce the volume of air where the dustcap would be causing flow to be accelerated past it and pushing the acoustic centre forward? and the shape of the phase plug is to ensure the correct effect at all frequencies of interest? I did read something about this once (about 10 years ago).
| Acoustic center of horns | mrkramer | Multi-Way | 5 | 29th January 2009 08:32 AM |
| Determining Acoustic Center | akunec | Multi-Way | 4 | 24th May 2007 08:31 AM |
| A (re)introduction to all, and a specific acoustic center question | gtphill | Multi-Way | 2 | 19th March 2007 03:31 AM |
| Dynaudio D76 Acoustic Center? | DaveThreshold | Multi-Way | 2 | 20th May 2006 11:35 PM |
| Center to Center of Drivers 29" apart in proposed config - Problems?? | Ken L | Multi-Way | 14 | 3rd November 2003 12:49 PM |
| Page generated in 0.08681 seconds (73.96% PHP - 26.04% MySQL) with 10 queries |
