Old 17th April 2006, 07:42 AM   #1
Default Ringing midrange
How to tweek a crossover to suppress ringing tones in the 400 to 800 HZ. My speaker is a 3 way 2nd order xover at 250 and 2500 Hz. components are SS 2905/9500 Tweeter, Vifa PL 14 Mid and SS 8555-00 bass, I've tried to change the mid driver with focal W 4211 or SS Kevlar but it only made it worse , especially the voices and the higher piano notes . I'm a beginner really in need of advise . The software I use is Xover Pro !
JP Haggar
Old 17th April 2006, 08:40 AM   #2
pinkmouse's Avatar
You need a frequency response plot to see the extent of the problem before you can design anything to sort it out.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 17th April 2006, 09:53 AM   #3
tinitus is online now tinitus  Europe
You can try and ad some resistors to paralel components in crossover - and I think you need an RC on bass
Old 17th April 2006, 10:04 AM   #4
lndm is offline lndm  Australia
I looked at Xover Pro's web page and as far as I can tell, it does not incorporate the measured frequency response of the drivers. This is referred to as a 'feature'. In fact, this limitation (if I didn't misread the page) will not recognise cone breakup and as you're no doubt aware, cone breakup is a larger issue in crossover design.
Old 17th April 2006, 11:18 AM   #5
Looking at woofer - it does have cone break up like it was a metalcone
Old 17th April 2006, 12:53 PM   #6
Sorry to reply so fast again - you refer to ringing as being in the 400 to 800hz region - so I suspect you hear it on saxofone low midvoice and deeper strings on violins etc. - if so I am almost certain it is a crossover malfunktion - maybe phase problems - the lowest crossover point is very difficult to get right.
Old 17th April 2006, 01:04 PM   #7
I have a hump at around 800Hz and I use an RLC string in parallel with the woofer. It works well but is difficult to design without crossover simulation as results are often touchy and/or unpredictable.
Old 17th April 2006, 02:33 PM   #8
Thanks guys , will certainly get something out of your advise ,
will keep you posted as to my results.
JP
ADC without pre-ringing jzagaja Digital Source 3 3rd July 2007 08:22 AM
multivibrator ringing ? Bazukaz Solid State 3 22nd May 2006 02:26 AM
PSU Ringing Kashmire Pass Labs 1 11th January 2005 08:31 PM
Ringing Mosfets Rog Solid State 1 2nd March 2004 09:21 PM
Acoustic ringing? grataku Solid State 1 15th March 2001 04:55 AM
Page generated in 0.08489 seconds (75.34% PHP - 24.66% MySQL) with 11 queries
