Ok, i've seen what a line-level BSC circuit can do (as per Rod Elliott - sound.westhost.com ), but i'm real curious.. Does a passive BSC do the same thing? i.e. attenuate sound above a certain frequency in a shelf manner.
#2 |
yes, absolutely.
#3 |
http://zaphaudio.com/audio-speaker12.html
In this design, Mr Krutke says he has about 4.5dB of BSC on the woofer. But all he has in the woofer crossover is the inductor (1st order low-pass) and the LC notch filter (for the 8KHz breakup node). I'm getting a tad confused |
#4 |
Khron,
The woofer driver is a complex impedance and judicious design with a minimal number of components can still yield the desired BSC curve. Take a look at the graph labeled "woofer filter effect." This shows the actual drive to the woofer and the shelving effect between 200-2000Hz that John was targeting. You'll see this kind of thing a lot with well-designed crossover networks......the actual topology might not look "generic" (or what you'd expect) but it still accomplishes the goal. Cheers, Davey. |
#5 |
Thanks Davey, that does make sense
| When to use baffle step compensation? | tmblack | Multi-Way | 28 | 6th December 2008 01:39 PM |
| Short TL as Baffle Step Compensation | m@ | Multi-Way | 0 | 10th March 2008 10:07 AM |
| Baffle step compensation formula? | bart_dood | Full Range | 4 | 8th July 2006 11:50 AM |
| Passive baffle step compensation | noodle_snacks | Multi-Way | 5 | 10th October 2005 07:20 PM |
| Baffle step compensation in an active X/O | sunil | Solid State | 6 | 12th November 2003 10:52 AM |
| Page generated in 0.09033 seconds (73.12% PHP - 26.88% MySQL) with 10 queries |
