Old 15th April 2006, 07:17 PM   #1
Default speaker response mesurement
In order to go active with my Zanszen Z2-CF speakers, I have started to mesure the drivers (10" closed suspension woofer + electrostat mid/tweeter, crossed at 800Hz with the passive old crossover).
I'm intend to use Jens and Bob Ellis active crossover from the diyAudio group buy.
software I used was Speaker Workshop,
with dynamic microphone and laptop (using the mic input- there is no line input in the lapptop PC).
I have took the sound card calibration while Instead of wire link from line out to line in, I used voltage divider (10K--100R) from the line out into the mic input of the laptop (1% of the signal from line out goes to mic in), this seems to be OK.
Problems/ questions:
1- MLS signal clipps - taking the volume output down in the Audio control panel making no change.
2- I did first mesurements with Audio-technica AT834-2 dynamic microphone, It have a 600Ohm impedance and it is too low output and too low impedance for my soundmax sound card in my Compaq nc6000 lapptop.
From reading here I learned it's better to use a flat respone with calibration file, condenser microphone like the Pansasonic WM-61.
I now VIKASH from the forum have these, but he now in holiday.
My question: is it necessary to use the WM-61 electret with the external mic amplifier? (As we can see at the Madaboutsound.com).
If I callibrate the software from the line output to the mic input, Means I can correlate the internal mic amplifer in my sound card- so why should I use an external mic amp?
(one more- do I have to correlate from the speaker workshop (calculate) or the software does this automaticely).
If it is not necessary I can connect the electret mic directly into the mic input at my laptop (Do I need 6v battary for the WM-61?).
If I have to use external mic amp. I will have to use my pentium3 450 old PC and probabely have to buy a modern sound card).
Last question regardings mesuring Dipole electrostat-
I found it diffecult (take this as understatment) to mesure correctly the high region of the dipole, from the fact that the microphone can be as close as say 40-50 cm from the dipole, and the response vary a lot from moving the microphone position.
Any help from experianced dipole users?
I now I had too many questions for a single post,
but any help will be welcome.
Thanks,
Avi.
Mesurement tools for sound. King Nothing Everything Else 0 19th December 2008 02:37 PM
Mesurement electret mic problems Bazukaz Parts 1 27th August 2006 03:13 PM
Why the emphasis on flat speaker response? jmikes Multi-Way 30 20th November 2004 05:18 AM
Speaker Response Problem sma Multi-Way 13 16th July 2004 10:56 PM
speaker frequency response sardonx Multi-Way 8 3rd December 2003 12:30 AM
Page generated in 0.07669 seconds (68.78% PHP - 31.22% MySQL) with 10 queries
