Old 28th April 2006, 04:28 PM   #11
Send a message via MSN to noodle_snacks
yep, i know that bit been doing it all week , would you say spraying it uses more or less contact cement? I have a spray gun appropriate for paint etc with my compressor, would i use it with that with some thinners? What sort of thinner should i use
Old 28th April 2006, 05:03 PM   #12
I don't have the space and ventilation for a spray gun and can't advise on proper mixing procedures. I have been told it works better than the aerosol can adhesive I currently use - oh well.
Audial Delta
- Hear the difference!
Old 29th April 2006, 03:46 AM   #13
hehe, its a bit slow, but a brush and a 4 litre tin of the stuff seems to work well enough for me, and thanks to the fact that contact is a bit gooey, there is almost no cleanup involved
Old 17th June 2006, 08:43 AM   #14
Attached is a macro photo of the job i did trimming the speaker carpet (changing blades every 12in or so for the recesses)
Cutting holes in aluminium enclosures emperor Parts 4 22nd July 2007 08:45 AM
Cutting Nice Holes jwatts Multi-Way 10 9th February 2005 01:46 PM
Is Rotozip a good tool for cutting holes? AJ Bertelson Multi-Way 10 9th June 2004 08:36 PM
Best method for cutting driver holes? dc Multi-Way 16 29th May 2002 01:27 PM
Page generated in 0.07951 seconds (68.05% PHP - 31.95% MySQL) with 11 queries
