Hello all,
This is maybe a stupid question but are there any drawbacks of wiring the 4 Ohm drivers in series in this design? Is it more wise to choose the 8 Ohm version of these and wire them in parallel? Woofers are the Vifa MG22WO09-04ohm midranges the Vifa MG14WK09-04ohm and tweeter the Morel MDT-33. The speakers are WMTMW tower, about 90 litres cabinet for the woofers tuned to 28Hz (EBS, Extended Bass Alignment) and 4 litres for the Mids. Drivers are Time Align. The design was inspired from the Duntech Prince. Regards P |
#2 |
The mid has a sensitivity of 89dB. What's the sensitivity of the woofer?
You get no sensitivity gain if you wire the woofers in series, so the combined woofers will have a sensitivity way below that of the midrange, and even more so when you factor in baffle step. I wouldn't recommend you use 4 ohm woofers in this type of design. |
| Vifa TL design WMTMW | downunder555 | Multi-Way | 11 | 13th May 2009 11:22 PM |
| Building some WMTMW | quickshift | Multi-Way | 16 | 16th September 2008 12:50 PM |
| WMTMW using the TB W4-1320SB | saabracer23 | Multi-Way | 2 | 13th April 2007 04:21 PM |
| WMTMW, more bass? | elambert | Multi-Way | 0 | 16th September 2005 04:39 AM |
| Would this be MMTMM or WMTMW... | elambert | Multi-Way | 3 | 23rd July 2005 03:08 AM |
| Page generated in 0.07910 seconds (71.40% PHP - 28.60% MySQL) with 10 queries |
