diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Speakers: 8 ohms vs. 16 ohms (http://www.diyaudio.com/forums/multi-way/77738-speakers-8-ohms-vs-16-ohms.html)
KT 14th April 2006 04:45 PM
What are the advantages or disadvantages to using a 16 ohm speaker over a 8 ohm speaker with a small class-D amp like the SI T-amp or DIYParadise Charlize, or a chipamp like the Gaincard/Gainclone?
Also, I realize it's an impedance mis-match, but what happens when I drive a 16 ohm speaker with the 8 ohm tap of my tube amp's output transformer?
I just purchased a pair of 16 ohm speakers. Everything I've been using up to this point has been 8 ohms.
Thanks,
KT
Nigel Goodwin 14th April 2006 04:49 PM
Re: Speakers: 8 ohms vs. 16 ohms
You don't match impedances on a transistor amplifier, all using 16 ohm speakers will do is half the available power output.
Even with a valve amp it's not a disaster, but it's not recommended, you lose power output, and put extra strain on the valves, output transformer, and power supply.
BWRX 14th April 2006 05:06 PM
Class D amplifiers with the output filter outside of the feedback loop, such as the Tripath amps, have a load dependent frequency response. The values of the inductor and capacitor in the output filter are tuned for a certain load. You change the load impedance, you change the frequency response.
Copyright 1999-2017 diyAudio
