Hi
FAQ 20 for SL's PHOENIX (www.linkwitzlab.com/faq.htm#Q20) says: “ . . . and since each driver is only used over part of its frequency range, because the active crossover limits the range that each amplifier has to cover, effective load impedances become approximately 4.5 ohm for the tweeter, 3.5 ohm for the midrange and 6.5 ohm for the woofer” The midranges and (usually) the woofers are paralleled, and mine will be. Who knows if the above are (apparently) for ohms impedances for the individual drivers, so that if single amps are used for each band, the load impedances come to only 1.75 ohms for the midrange and 3.25 ohms for the woofer? Thanks Richard |
| Dynamic load line analysis using music and speaker load | Michael Koster | Tubes / Valves | 0 | 7th March 2008 08:47 PM |
| Matching Impedances | dscrobe | Tubes / Valves | 3 | 26th September 2007 06:49 AM |
| How many amperes for a parallelled lm4780 | jaste | Chip Amps | 2 | 24th January 2007 06:00 PM |
| 16ohm parallelled crossover | ocool_15 | Multi-Way | 2 | 8th October 2005 04:56 AM |
| What's the closest I can get to a 4 ohm load using 3 single coil, 6 ohm drivers? | The Paulinator | Multi-Way | 9 | 11th May 2004 07:04 PM |
| Page generated in 0.05947 seconds (81.94% PHP - 18.06% MySQL) with 10 queries |
