my new way to build a TML
Old 21st April 2006, 06:58 AM   #21
Roemhild is offline Roemhild  Germany
Roemhild's Avatar
here is a picture ov the X-over
I have used a 12mH coil and a 68F capacitor.
it is just a first try without any soldering
http://www.hornlautsprecher.de
Old 23rd April 2006, 10:29 AM   #22
Roemhild's Avatar
Default last update
so now I have changed the positon from the FX-horn and my TML. Now the TML is playing alot deeper and with more control.
I have reduced (with success) the volume in the lower line to get a bit more details in the Bass.
cya Till
Old 23rd April 2006, 10:41 AM   #23
Cortez is offline Cortez  Hungary
Cortez's Avatar
Sorry, I didnt still get it, whats the special in this TML design ?
It is a simple TL, isnt it ? (the driver placed in ~1/3 position)
Otherwise do you have a measured freq-response ?
Old 23rd April 2006, 11:06 AM   #24
Roemhild's Avatar
the "normal" design is that you use the surface area [Sd] from the driver for the opening area [Am]. The staring area [Ah] from the TML is 1.5 ... 2.0 times larger.
Than you have the length [l] of the TML according do the resonace frequency.
With a 12" with 25Hz would that mean:
Ah: 810cm (1.5x Sd)
Am: 539cm
l: 3,58m
The complete volume of the TML would be 241ltr.
I started with the volume. I thought that a TML needs 1.5 ..1.6 times more volume than a normal BR. My driver needs 100ltr BR so the TML has got to be 150ltr.
The reso of the driver in 160ltr would be around 45Hz. I have placed the line frequency between the driver reso (25Hz) and the volume reso (45Hz) = 35Hz
Now I know that the line has got to be 2.75m long.
Ah is 1.6 times bigger than the Am.
Using the formulas I calculated how big Am and Ah will be.
The driver is just at 1/3 of the length like in a usual TML.
hope I could explain it to you.
cya Till
Old 23rd April 2006, 11:46 AM   #25
Cortez's Avatar
Yes, its clear now, thank you !
And why is the bottom end shorted with that wall down there ?
Or this is: "The lower camber is to adsorption a frequency at 200Hz." ?
I have a 10" driver:
http://www.d-s-t.com/link/vifa/data/m25wo-49-08e.htm
Do you think it would be appropriate for a TML ?
Old 23rd April 2006, 12:26 PM   #26
Roemhild's Avatar
Yes the the lower camber is to adsorption a frequency at 200Hz.
I will simulate the driver for you in a TML
First try would be:
Old 23rd April 2006, 12:50 PM   #27
Cortez's Avatar
And where is the port ? I cant see anything on the pictures about this.
Otherwise it seemed to work really ?
Thank you very much ! I like this design, cause I wanted a similar
layout, cause I have also a fullrange what could go to the top.
Its a fostex fe-166.
Old 23rd April 2006, 01:34 PM   #28
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Is that thing on the back wall a 21" driver?
I use to feel like the small child in The Emperor's New Clothes tale
Old 23rd April 2006, 02:36 PM   #29
Roemhild's Avatar
hi,
it is a 31" (FW800N from Fostex).
greets Till
Old 23rd April 2006, 02:54 PM   #30
Eva's Avatar
What a crazy thing
my new way to build a TMLHide this!Advertise here!
I want to try and build my own DAC gareth Digital Line Level 3 3rd July 2009 03:20 PM
ZV9 build ingi Pass Labs 8 6th August 2006 02:40 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
