my new way to build a TML
Old 12th April 2006, 04:33 PM   #11
Roemhild is offline Roemhild  Germany
Roemhild's Avatar
Hi RJ,
I just replied your mail.
if someone else would like to have the sheet give me a note via email.
the sheet looks like that:
http://www.hornlautsprecher.de
Old 12th April 2006, 05:28 PM   #12
Bose(o) is offline Bose(o)  Canada
GOTCHA! Looks great from what I can see. Also, what wood are you using for the curves in the line?
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 12th April 2006, 05:47 PM   #13
Roemhild's Avatar
German name is HDF (high-desity-fiberboard ??) and is 3mm thick. Perfekt to bend.
greetz Till
Old 12th April 2006, 10:26 PM   #14
edjosh23 is offline edjosh23  United States
edjosh23's Avatar
I too would like the spreadsheet.
I'd also like those FX200's. haha
If only they were still in production
The project looks good so far.
Josh
Old 13th April 2006, 10:20 PM   #15
Roemhild's Avatar
Default latest update
here is my last picture. Next week I will build in the Coral 8A-70. Right now a 17cm Philips fullrange speaker is added.
The sound is getting better every hour. The woofers are new and the sound was a bit strange in the beginning. Now it is getting better and better
cya Till
Old 14th April 2006, 04:14 AM   #16
Wow, you work quickly, is it you week off? Good work none the less, I love seeing your updates. Is there any chance that you'll be able to take any measurements?
ERTW 4 life!
Old 14th April 2006, 05:23 AM   #17
zobsky is offline zobsky  India
zobsky's Avatar
HDF = "masonite" here in the US, if i'm not mistaken
you should be able to attach spreadsheets (or zip them up and then attach the zip files)
good work, ...what's the other speaker in the pic?
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 14th April 2006, 07:07 AM   #18
Roemhild's Avatar
hi zobsky,
wath speaker do you mean? the left is a Fostex FX200 in a BL-horn from me.
And the Coral 8A-70 is an old fullrange speaker with very good parameters as you can see on the datasheet.
The woofer I am using is a Fostex W300A-II
Hi Bose(o)
I don't use measurement but I hope a friend of mine will/can help me out with that. If I have pictures I will post them.
No I am still working 9hours a day. I am working with the TML between 7:00pm - 01:00am.
my motto right now: the day has 24hours. If that is not enough take the night. or you can sleep when u are dead.
Old 14th April 2006, 05:37 PM   #19
I love the motto and am anxiously awaiting updates.
ERTW 4 life!
Old 21st April 2006, 06:54 AM   #20
Roemhild's Avatar
since yesterday evening the TML is playing with the Fostex woofer and the Coral fullrange speaker.
So far I am very happy with the sound. The TML is playing very deep and with a lot more control than the FX-horn. Sometimes you have the feeling that the woofer is not on and as soon as you want to check the wireing you can feel and hear the bass. It is never intrusive (??) or booming.
The sound of the Coral is fitting perfect to the sound of the Fostex.
I will play the next days with the volume and the X-over.
cya Till
my new way to build a TMLHide this!Advertise here!
I want to try and build my own DAC gareth Digital Line Level 3 3rd July 2009 03:20 PM
ZV9 build ingi Pass Labs 8 6th August 2006 02:40 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Copyright ©1999-2017 diyAudio
