Old 10th April 2006, 09:03 AM   #1
Send a message via MSN to Toast_Master
Default What do you think?
Hey
I may want to make cheap (only because the drivers are) High end speaker
the speakers involved are pioneer 3 way 10" coaxial car speakers, I cant find any specs except that they can take 100 watts rms each
I have heard that having all the acoustic centers the same will give awesome image so I plan to buy 2 pairs so there are 2 coaxials in each floorstander
I have more info but before I unleash it all I just wanna know is this acceptable?
Old 10th April 2006, 09:12 AM   #2
maxro is offline maxro  Canada
maxro's Avatar
Default Re: What do you think?
Two seperate drivers per speaker will negate the "awesome image" of a coaxial. You could, however, put the second pair on the backs of the cabs and make bipoles.
As far as car drivers being acceptable, only you have to listen to them. So, if you can accept them, then that's all that matters.
Max
Old 10th April 2006, 09:52 AM   #3
Yes I see your point.....cause there will be to centers
Also I know nothing about bipole..could you give some essentials
I know alot..or enough about sealed and vented
thanks
Old 10th April 2006, 10:02 AM   #4
lndm is offline lndm  Australia
Coaxial car speakers do not have the acoustic centres aligned. Ok if you look from the front, but look from the top. In fact these are guaranteed not to be aligned unless you electrically delay the highs. At least with separates, you can tilt the cabinet to suit your listening position.
P.S. they may still sound good though
Old 10th April 2006, 02:19 PM   #5
sdclc126's Avatar
thanks
Here is a bipole speaker design:
http://www.t-linespeakers.org/projects/tlB/index.html
There are a few others on the site if you search around. These and dipole/open baffle designs, also on the site, will work well if you have enough room, as they need to be placed some distance from your walls.
Soft Dome
Page generated in 0.08520 seconds (73.90% PHP - 26.10% MySQL) with 9 queries
