| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
I'm building a sub out of MDF and I'm experimenting with a piano finish. I've just brushed on the first coat of primer, (50/50 glue and water), and I'm wondering how many coats y'all typically apply. Is it ideal to sand w/440 or above between coats?
#2 |
I may be wrong but isn't that a lot of water in with the glue? I wonder if that will cause swelling?
Read dozens of books about heroes and crooks and I learned much from both of their styles. (JB) |
#3 |
PVA + water mix isn't a great way to seal the cabinets. It works but there's more effective treatments:
Specially formulated MDF primer: http://www.international-paints.co.u...1&surfaceid=48 And the best is a resin based wood hardener: http://www.decoratingdirect.co.uk/viewprod/b/BONWH/ Apply one of those in generous quantities and then sand back smooth with an orbital palm sander and ~400grit paper. Be prepared for a ton of work and use lots and lots of automotive primer after you've sealed the cabinets with one of the above. |
#4 | |
#5 |
50/50 is the mix that seems to be stated over and over again around these parts. I was concerned about swelling as well but it actually seems to dry pretty quickly and I can't see any evidence of expansion.
#6 | |
Guess I'm pretty committed to glue and water at this point, I'll give it a light sand and give it another coat with a thicker mix. |
| Thread Tools | |
| primer for fiberglass | pjoseph | Subwoofers | 5 | 4th August 2009 12:03 AM |
| Fi Primer 807 | Klimon | Tubes / Valves | 2 | 13th November 2007 07:58 AM |
| A cooling Primer? | Pbassred | Solid State | 9 | 29th March 2007 06:00 PM |
| Loudspeaker primer for the novice | Stephen | Multi-Way | 16 | 17th December 2003 02:01 PM |
| Water cooled plate on ebay (possible water cooled amp application) | BrianGT | Parts | 1 | 27th May 2002 04:19 PM |
| Page generated in 0.21473289 seconds (66.01% PHP - 33.99% MySQL) with 10 queries |
