Old 9th April 2006, 03:52 AM   #1
Default Decorative trim rings
I'm building some speakers that will front mount an Altec 416-8C woofer. Do you have any suggestions on trim rings to cover the frame on the 15" woofer? Maybe stack some 3/4 mdf and router some rings that fit over and around the woofer, some kind of plastic trim that could wrap around the woofer or some company that already makes trim rings this large.
Old 9th April 2006, 06:55 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
If you want it neat and tidy, why not mount the drivers from the rear? A neat removeable hatch in the rear will be less ugly than front mounting and trying to cover up the rim.
Here is an example using a 12 inch driver.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 10th April 2006, 11:30 AM   #3
The speaker build design does not allow for rear access.
Old 10th April 2006, 12:33 PM   #4
Nuuk's Avatar
Another reason to go open baffle!
OK, recess the drivers and make up a cover plate that you fix with magnets or velcro.
this 22K trim pot pjanda1 Parts 4 20th August 2008 04:08 PM
Wanted - perforated or decorative metal for grills solid7 Swap Meet 4 12th May 2008 12:35 AM
Source for decorative bolts, washers? samtny Multi-Way 5 30th January 2008 07:07 PM
Need decorative momentary for my amplifier chassis mp006ltk Parts 2 26th May 2006 07:47 PM
Page generated in 0.07971 seconds (70.86% PHP - 29.14% MySQL) with 10 queries
