Old 8th April 2006, 12:30 PM   #1
Default Soundeasy PC requirements
Couple of quick questions. I recently purchased Soundeasy and it arrived yesterday and I’m anxious to use it. I’m working 7-12s for the next couple months so I won’t have a lot of time to play, but once this is over I want to be 100% ready.
I purchased an Emu 0404 sound card for measurements, I’m hoping it will work well, but I need to upgrade my PC. The Emu needs a minimum of 1.2 Ghz machine and the Soundeasy needs a 1.7Ghz, my shop PC is an older socket A AMD 900Mhz. So I need to upgrade my shop PC.
I haven’t built a machine since the shop PC, about five years ago, so I’m out of date on processors and motherboards. For some background, there are 4 desktops and two laptops in my house. The ones in the house are newer and faster, pre packaged machines.
So what I want to build is a dedicated machine for Soundeasy and music and I don’t want to spend a fortune nor do I want to buy another pre packaged machine that has tons of useless software on it. So can anyone tell me what kind of machine they are running with Soundeasy and how they like the results or direct me to a good combo for a machine. I’m leaning towards another AMD setup, Asus K8V-X SE Socket 754 ATX Motherboard and an AMD Athon 64 3300+ 2.40GHz CPU. Any thoughts, is this more than I need?
Old 8th April 2006, 03:08 PM   #2
soongsc is offline soongsc  Taiwan
soongsc's Avatar
You will probably need that fastest you think you can affort when you start generating plots and using the design features. I look at data on my AMD 64 3000 1.8G, and it takes about a minute to generate a waterfall plot. On the notebook I use to do measurements, it took probably 10 minutes. Just to give you an idea.
Hear the real thing!
Old 8th April 2006, 07:32 PM   #3
Thanks soongsc, I'm getting ready to press the button on an order. I have a desktop dynop pragram I use for crunching engine specs and its a cpu killer. I'm sure the waterfall plots are a real number chruncher also. So no low end CPUs and lots of speed. Better rethink here.
Any one else out there have some comparisons?
Help with BTL power requirements dayveshome Solid State 5 28th March 2008 11:45 AM
subwoofer requirements blue934 Car Audio 10 17th February 2008 10:27 PM
Ladegaard Arm Air Requirements ? valveitude Analogue Source 10 1st February 2007 08:06 AM
What Are The Requirements For EU Membership? kelticwizard The Lounge 29 23rd April 2004 03:39 AM
Page generated in 0.76605 seconds (11.25% PHP - 88.75% MySQL) with 10 queries
