Old 18th November 2002, 12:24 AM   #1
Andy G is offline Andy G  Australia
Andy G's Avatar
Default MTM’s or TMM’s: using sealed upper and TL (or similar) lower drivers?
I know this sort of configuration theoretically introduces different “Q”, group delay , phase etc etc on the 2 “M” drivers if they are wired in parallel, but so does adding a coil on one of them in a 2.5, doesn’t it ??
Is this configuration really just a cabinet introduced 2.5 ??
How much does the different loading on the two drivers effect each of the drivers?
In an MTM, how much does introducing these anomilies effect the lobing, and other sound qualities?
and does the same apply if they are in a TMM configuration ?
Is there any simple way of electronically counteracting any group delay or phase problems this configuration might introduce??
So many questions, hope someone can answer !!
Old 18th November 2002, 12:34 AM   #2
planet10's Avatar
Default Re: MTM’s or TMM’s: using sealed upper and TL (or similar) lower drivers?
I'll only sidestep this a bit... the 2.5 has the phase differences at the top of its range (and these can be mostly shielded from the FR driver by the cabinet if you mount the 0.5 driver on the back).
Different driver loading effects the bottom of the drivers range where the wavelengths are much longer.
To judge the magnitude of the effect you would have to add the complex FR (mag+phase) of the 2 together.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th November 2002, 03:25 AM   #3
Jimmy154's Avatar
I seem to use this link a lot cause I don't know many websites, but it seems to be relevent http://home.hetnet.nl/~geenius/Auriga.html This dude made a 2.5-way with a sealed top woofer and vented bottom woofer.
We do not allow political statements or conjecture to be made on these forums.---the diyAudio moderation team
Old 18th November 2002, 05:46 AM   #4
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
me think a aperiodic or TL bottom driver would pose less of a problem than a ported. just instinct.
another alternate is to TL both the drivers in indepenant TLs.
my definition of a TL here is a well damped TL which absorbs almost all of the back wave.
my 2 paise worth :-)
...still looking for the holy grail.
12 " for lower midrange - upper bass Audiodidakt Multi-Way 33 23rd June 2009 05:39 PM
why do larger drivers beam upper frequencies? mrkahn Full Range 10 20th March 2009 06:13 PM
veneering upper/lower baffle corners Ang Multi-Way 1 11th January 2007 11:03 PM
Upper and lower triode in E88CC Andypairo Tubes / Valves 7 8th March 2006 07:51 AM
sealed sub 15" 20hz or lower chainenoble Subwoofers 21 4th March 2006 05:30 AM
Page generated in 0.06985 seconds (83.38% PHP - 16.62% MySQL) with 10 queries
