I’m considering buying an old guitar speaker that may prove it needs a new cone before too long - what scope there is to tweak TS params a little, and maybe improve control.
If a driver is reconed, and a different material to the original is used, am I right that: If it's heavier material of similar stiffness, Fs will be lowered so the bottom end extended, but top end extension is likely to suffer? ~ If its lighter, vice versa? If the material is stiffer, eg using Kevlar instead of the original paper, control may improve. Thanks |
#2 |
changing the cone will change the Voice coil, Surround, Spider, as well as the cone mass and stiffness. These other changes will affect a number of parameters. Not just Fs. I cannot confirm exactly which but likely changes are VAS, Fs, Mms, BL, Re, etc. You could tweak to your advantage but just as easily go in some wrong directions. Hopefully someone will post an exact list of changed parameters and how they relate to the basic cone/surround/voice coil.
regards Andrew T. |
#3 |
Hi Andrew and all
I wasn’t thinking Fs would be the only change. I am hoping to essentially get a feel for the likely change in “operating range”, from a change in material. Thanks Regards |
#4 |
So who's done recone?
Cheers |
#5 |
do a search in this forum and find my driver design spreadsheet. You can plug in variables and see how the T/S params are changed.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#6 |
Ron
I found your spreadsheet thanks. Diy dynamic driver But it’s protected, so I can’t change anything w/out a password. . And while it looks very handy, I can’t see that cone material is a factor. Regards |
#7 |
You don't expect me to give it away, do you
This spreadsheet only calculates T/S, which are essentially unaffected by cone material, other than the weight, which is variable. Cone shape, cone material, and surround properties all affect the response above the range where this spreadsheet can predict ...
#8 | |
One thing that can't be predicted and is extremely likely to change is the cone breakup frequency, as well as how gracefully the driver transitions into that frequency region and how annoying the cone breakup sound is. Cheers! almost forgot - reconing will also probably mean changing the surround material, causing more differences. Termination (affecting modals) , mechanical damping as well). |
#9 |
So what is known or predictable?
Who has read Colloms recently? Cheers |
| Thiele - Small parameters | tomtt | Multi-Way | 0 | 25th March 2009 02:48 AM |
| Thiele-Small parameters | Hoffmeyer | Multi-Way | 6 | 15th March 2006 01:12 AM |
| DIY Thiele/Small measurements ?? | youyoung21147 | Full Range | 19 | 5th October 2005 05:10 PM |
| Thiele-Small Explained? | marob | Multi-Way | 3 | 19th April 2005 07:10 PM |
| Thiele-Small importance | bigswede | Multi-Way | 4 | 12th September 2002 07:21 PM |
| Page generated in 0.10027 seconds (78.75% PHP - 21.25% MySQL) with 10 queries |
