Hi! I'm new to loudspeaker building, and I need some advice about creating the filter. The design I use is a model from TNT audio called primaluce the design
I have switched the loudspeaker parts out with elements from SEAS. the woofer with SEAS W22EX-001, the midrange with SEAS W15LY001 and the tweeter with T25C003 . What I need answer for is what type of filter I should make, the cut-off and other general tips. Thanks for any response. |
#2 |
Speakerholic
Hi AS,
General tips? OK, you don't just swap parts, you design the boxes and XO's for the drivers. If you have the T/S parameters for both sets of drivers you can sometimes adapt. A good starting point for XO's is 12dB/octave. Without a lot of experience your idea can backfire on you and leave you very disappointed. Sorry for the downer but it's a tall order. |
#3 |
i have designed the new boxes so it will fit the drivers. I used a excel spreadsheet (unibox)
#4 |
alladin - the problem is that the xover is the main part of any speaker design, and the most difficult to do. It isnt just something like box design where you throw a few parameters into some software and it spits out correct alignments. It is also specific to the driver combination used.
Without good measurements of your drivers in your baffle, no one is going to be able to design a crossover for you. Basically what Cal was trying to say (nicely) is that you were wrong to assume you can swap out the drivers and easily make a new crossover for them. You are designing a whole new speaker. If you want to do this right, I suggest you get some measurement capability, the cheapest way is probably to buy a behringer ECM8000 mic and a UB802 mixer, then get some measurement/design software. Good free software includes speaker workshop, or the FRD consortium tools. good commerical products are LSPcad and Soundeasy. Be forewarned that with it will take a long time and lots of learning to get a 3 way sounding good. I know this is probably not what you want to hear, but thats the way it is. |
| Page generated in 0.08475 seconds (73.78% PHP - 26.22% MySQL) with 9 queries |
