Old 6th April 2006, 03:55 AM   #1
dalcorn is offline dalcorn  United States
Default low end woofers
What is the best approach to take in the low frequency range (~35Hz) ?
I have built my own bookshelves and thought i might just make some dual 6.5" woofer floorstanders and a subwoofer.
I have looked at some of the 15" woofers out there and what not, and saw extreme cases of designs with ~27-31" woofers.
The bookshelves I designed were sealed enclosures and I want to stick with that.
Room size is 12' x 19' (living room)
Old 6th April 2006, 04:17 AM   #2
Bose(o) is offline Bose(o)  Canada
I'd recommend going with something of your preferred resistance flavour by Adire Audio. Of course, though, I have to ask if you want active/passive because woofer just doesn't sound the same when run passively.
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 6th April 2006, 04:25 AM   #3
probably active crossover and biamp... woofer on one amp and then high/mid on another
Old 6th April 2006, 04:34 AM   #4
http://www.acoustic-visions.com/~aco...dire_extremis/
6.8" seems good? first time seeing it
i might just need 1 of those.... not too sure... i suppose i'd get more bass with a tuned ported enclosure? i'd prefer to do sealed but maybe someone could convince me otherwise
Old 6th April 2006, 05:34 AM   #5
spamming my own post... but reading more i think i want to do a vented enclosure to get the lower bass response...
not sure if i should do two of the 6.8" drivers in parallel....
Old 6th April 2006, 07:16 AM   #6
Calvin is offline Calvin  Germany
Calvin's Avatar
Default Subs
if You want deep and precise bass I strongly discommend vented enclosures like BR or BP. They donīt give precise bass with very low tuning frequencies. The group delay reaches values which are audible.
Better stick to closed subs with bigger drivers or dipoles. Keep in mind the room gain, which boosts bass response.
jauu
Calvin
Old 6th April 2006, 01:35 PM   #7
Send a message via MSN to blank527
Have a look at the Peerless XXLS series.
Greetings,
Remco Blankesteijn
Old 6th April 2006, 03:32 PM   #8
Sooo, you want small drivers for the sub??
The Adire Extremis, is really, EXTREME, I love it. I'm using one in my frined's Jeep and, soon to be another added in parallel. They are very good woofers and are very reliable under the abuse of the automotive environment.
ERTW 4 life!
Old 6th April 2006, 08:23 PM   #9
Not necessarily small... just I wasn't sure if they offered a better solution than a very large woofer
15" woofer versus 6.8" extremis....
the dayton hi fidelity 12" seems like the best cost/benefit ratio of what i've seen
Old 6th April 2006, 08:24 PM   #10
i suppose i should clarify that this is for a home audio 2CH setup...
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 09:57 PM
Using three woofers rackmount Subwoofers 1 8th November 2006 01:16 PM
PHL woofers!!!! tadman Multi-Way 21 9th June 2004 10:58 AM
FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers cm7 Swap Meet 0 1st August 2003 01:59 PM
Using DVC woofers as 2 seperate woofers Hybrid fourdoor Multi-Way 2 15th June 2003 12:10 AM
Page generated in 0.10740 seconds (74.73% PHP - 25.27% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
