Is there a conversion table or formula somewhere? Thanks.
#2 |
Warp Engineer
On Holiday
It's not a a set conversion but rather a relative relationship. Everytime you double or halve the frequency, you cover an additional octave. So, 10 to 20Hz is an octave and also 5kHz to 10kHz is an octave.
- Dan |
#3 |
If you want to correlate with notes, the usual starting point is the A above middle C, at 440 Hz. From there it's a matter of doubling and halving as AudioFreak said.
There may be a table somewhere, but individual notes in between the "A"s quickly start to take on awkward values with lots of places after the decimal point. |
#4 |
There are 12 notes per octave in the equal-tempered scale. Including the black ones on the keyboards of pianos, synths etc. So to get from one note to the next up, multiply by the twelth root of two (1.059463094 by my calculator). So A4 = 440. Then A#4 = 440 times 1.059463094 = 466.1637615.
There is a nice table of note frequencies here http://www.phy.mtu.edu/~suits/notefreqs.html There are other scales beside the equal-tempered, do some googling on "musical scales" and such. It's quite fascinating.
For me the past is not over yet. |
#5 |
Excellent. Thanks for the help!
| Converting TO-220 to TO-247 | Clipped | Car Audio | 5 | 24th July 2007 06:59 PM |
| Converting a DAC-in-the-Box to I-out? | Aleksunder | Digital Source | 0 | 26th May 2007 11:44 AM |
| Converting a DCC into a DAC | harrygrey382 | Digital Source | 0 | 21st May 2007 10:10 AM |
| Zero mH Drivers, Clarity and Time Differences Between Octaves | kelticwizard | Multi-Way | 0 | 17th December 2005 02:15 PM |
| cabin gain,, and octaves | jadenlinkletter | Car Audio | 4 | 12th April 2005 02:35 AM |
| Page generated in 0.08877 seconds (71.34% PHP - 28.66% MySQL) with 10 queries |
