Old 3rd April 2006, 12:00 PM   #1
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Send a message via MSN to lykkedk
Question AnyOne know the model-name of my loudspeaker's ?
The loudspeaker, is a Dansih-made by : F3 (now Audiovector).
Anyone know the excact name ?.
I am driving them with a LeachAmp 4.5, which grow's hot, when playing loud.
I was wondering if a Krell-Clone KSA50, was better driving them ???
You can see some picture's at my Amp, if you're interested here
LINK
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp.
Old 3rd April 2006, 12:09 PM   #2
tool49 is offline tool49  Canada
tool49's Avatar
Looking at the pictures of your Leach amp, it's obvious to me that it will become hot no matter what load your speakers are. You really need to ventilate these heatsinks where the transistors are if you want it to stay cool. The Krell KSA50 will become just as hot if assembled similarly (or even hotter because of the higher idle bias)
Hope this helps!
Sébastien
Old 3rd April 2006, 12:15 PM   #3
lykkedk's Avatar
Yes I know, but maybe the Krell could drive more power ? (I would like too) I would like a 'bit' more power.
Sorry I forgot to mention that.
Old 3rd April 2006, 12:17 PM   #4
tool49's Avatar
Ahh well, that I will leave to those who have built both. I have no clue whatsoever!
Sébastien
Old 3rd April 2006, 01:01 PM   #5
lykkedk's Avatar
Anyway, I would still like some iformation about them loudspeaker, if possible !
Old 3rd April 2006, 04:05 PM   #6
Tomac is offline Tomac  Croatia
bass driver looks like Monacor SPH-212, can you check the sticker on magnet?
Old 3rd April 2006, 04:23 PM   #7
Hi Lykk,
even leaving the lid off the output stage will probably overheat.
You really need to get those heatsinks oriented the correct way and out in the open air.
Tread carefully with the volume control until this is sorted.
If those speakers are continental then they may be 4ohm. This will make your overheating problem even worse.
regards Andrew T.
Old 3rd April 2006, 04:53 PM   #8
lykkedk's Avatar
You mean like this at eg. the back of the cabinet ?
(Very bad drawing)
Old 3rd April 2006, 05:07 PM   #9
No,
with the fins horizontal you lose about 30% of the cooling capacity.
You need to orient them vertically.
Try cutting them in half. Then four side by side will have more cooling than two big ones side by side and the reduced height will fit the box you have.
OOPs, just had another look and there is not enough room to cut them in half and you then need to relocate the diodes.
regards Andrew T.
Old 3rd April 2006, 05:14 PM   #10
No I think at the back of the magnet of the bass unit. You'll hae to take the driver out to see. Is this
your bass driver?
DIY loudspeaker vs. factory built loudspeaker keyser Multi-Way 83 16th May 2011 12:27 PM
WTB: Loudspeaker Kit bjackson Swap Meet 0 3rd December 2005 08:18 PM
Loudspeaker for T-amp ecodoppler Multi-Way 2 14th October 2005 11:15 PM
Please help with my diy loudspeaker khorne Multi-Way 3 8th April 2003 08:38 AM
HELP 4 a DIY hi-end loudspeaker joz Multi-Way 6 1st February 2003 10:53 PM
Page generated in 0.10427 seconds (74.79% PHP - 25.21% MySQL) with 11 queries
