Old 3rd April 2006, 07:22 AM   #1
Default Best way to connect 4 woofers?
Could you experts please explain the sound / distortion differences of 4 woofers connected:
(2 woofers in series) in parallel with (2 woofers in series)
(2 woofers in parallel) in series with (2 woofers in parallel)
I know they have the same impedance and SPL and if all the drivers are ideal then they should make no difference. But in a real world the drivers may be different from each other therefore the possible effects of back EMF, etc for each connection may differ.
Background information:
I have 4 x 8" Peerless HDS woofers covering 40-300Hz in a WWMTMWW speaker.
A while ago I tried series connection of 2 woofers with a 100W SS amplifier and the sound was awful. I then tried parallel connection and it sounded good. But I wouldn't want the amp to drive a 1.5 ohm load by connecting the 4 woofers in parallel so I connected the 4 woofers in 2 parallel pairs and was planning on using 2 amplifiers for the 4 woofers.
I recently upgraded the SS power amps and they behave better. So yesterday I tried connecting the 2 parallel pairs in series with only one amplifier and it sounded quite good.
BUT, this isn't the normal way to connect 4 woofers to one amp. I think the normal way is to connect 2 woofers in series then connect the 2 series pairs in parallel.
Your input will be much appreciated.
Bill
Old 3rd April 2006, 07:27 AM   #2
Did it Himself
richie00boy's Avatar
Both ways are the same.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 3rd April 2006, 07:40 AM   #3
Do you mean electronically the same (as I agreed to when using ideal drivers)? The actual physical connections are different as the 2nd set of connections connects the "MID" point while the 1st set does not.
Old 3rd April 2006, 10:55 AM   #4
Hifinutnut,
Electrically, electronically the same.
The only difference is if 1 speaker is destroyed, (for the case which you described at the end of your post) 3 speakers will work.
Whereas the first case only 2 speakers will work even if only 1 is not working(or destroyed).
Old 3rd April 2006, 11:26 PM   #5
Thanks for your helpful replies. I am not worrying about them now.
Bill
How do I connect drclean Solid State 0 15th December 2008 06:03 PM
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 09:57 PM
best way to connect this amp.. jonz Solid State 2 18th May 2004 06:54 AM
FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers cm7 Swap Meet 0 1st August 2003 01:59 PM
Using DVC woofers as 2 seperate woofers Hybrid fourdoor Multi-Way 2 15th June 2003 12:10 AM
Page generated in 0.09092 seconds (73.67% PHP - 26.33% MySQL) with 10 queries
