ARTA
ARTA
Old 14th August 2006, 03:37 PM   #11
ente is offline ente  Germany
Default PLOP
don't call it trouble
The plop ist just a little bit annoying but it makes no trouble to your DUT (if you be careful with the input signal)!
Heinrich
Old 14th August 2006, 03:55 PM   #12
hooha is offline hooha  Canada
hooha's Avatar
Check your gain, it might be set too high.
Mark
Breaking speed records - http://www.mach5audio.com
Old 14th August 2006, 09:29 PM   #13
wigginjs is offline wigginjs  United States
wigginjs's Avatar
Default Re: PLOP
Heinrich
What is "DUT"?
Secondly, how is it possible that this very loud pop would not effect the measurement? Do I understand correctly that this pop is "normal"?
Old 15th August 2006, 02:05 AM   #14
hooha's Avatar
I have yet to hear a noise from the setup I have, other than what is suppose to be there. Hence, my suggestion about checking your gain.
Mark
Old 21st August 2006, 09:13 PM   #15
Default New release
Hi guys,
ARTA release 1.1.0 is available on Ivo's homepage:
http://www.fesb.hr/~mateljan/arta/news.htm
Have fun with it
Heinrich
Old 22nd August 2006, 04:25 PM   #16
kevinkr's Avatar
ARTA
I've been using Arta with an m-audio 2496 internal sound card and via spdif with an external dac. Works very well indeed. Will download the latest version shortly.
I like this enough that I will purchase it as a replacement for Audiotester which on both of my systems is quite buggy.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 31st August 2006, 06:51 PM   #17
ggta is offline ggta  France
I would like to use Arta with my Creative Audigy. Does someone know its imput impedance? Are the value R1=8200 ohms and R2=910 ohms ok for my soundcard?
Old 31st December 2006, 01:28 PM   #18
Wink ARTA 1.2
Delayed Xmas announcement.
In one or two weeks you can download ARTA 1.2. Here are some of the news:
ARTA
- CSD also as spectrogram
- directivity plot, new
- excess phase and excess group delay, update
- new IMD intermodulation distortion report (SMPTE, CCIF, DIN, IEC 60268-5), new
- new THD report
- max. impulse response sequence length extended to 256k (for reverberation time measurements in large rooms)
- reverberation time can be estimated in octave bands 62.5, 125,.. , 8000Hz
- output volume for multi sine extended to -30dB
- control of graph setup, update
- gate time can be shown as equivalent sound wave propagation distance in cm
- 192kHz sampling rate enabled
corrections of small bugs
- ascii file export of the step response
- correct swept-sine timing
LIMP
- optimized procedure for the estimation of TSP
Happy New Year
Heinrich
Old 31st December 2006, 03:30 PM   #19
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
I've been running the trial version of this for a few months now. I've got to say that its an excellent package that does all the important measurements with accuracy. Just in case you aren't familiar with what it can do here's the main attractions: Room, TS measurements, distortion, FR, phase, impedance, impulse and the list goes on and on.
The real bonus is that its so easy to use, with most measurements taking only seconds. This means more tweaking and less concentrating and messing around with software. Its also nice to see that its updated regularly with all the latest features.
I just bought it using the Share-it option on the ARTA webpage. I was amazed that it only cost £57, I was expecting it to be significantly more than that.
Whole heartedly recommended, probably the best measurement package out there - tons of power yet easy to use.
Old 31st December 2006, 04:02 PM   #20
lovechild is offline lovechild  Europe
That's great news Heinrich!
guten rutsch & happy new year @ all
LC
ARTAHide this!Advertise here!
Arta box. miklos Equipment & Tools 2 19th September 2014 07:27 PM
Help with Arta- HOLMImpulse viki_v2 Software Tools 2 12th September 2012 02:04 AM
arta vs cliowin ermes Multi-Way 0 4th March 2011 02:37 PM
ARTA - using ARTA to measure room acoustics! OMF Software Tools 0 25th November 2009 01:55 PM
ARTA help Cousin Billy Multi-Way 2 13th February 2009 12:16 AM
