#131 |
thank you for responding dbmandrake.
i redid the whole voltage probe thingy ,and now everything is ok. did a test with a 1% 5.6 and 6.8 ohm resistor ,and it comes close fyi, the pic i posted in post 127 is a imp measurement of a ht sub. already did a imp measurement whitout the voltage probe ,for ts parameters,that worked fine. tnx
one good thing about music ,when it hit you feel no pain. so hit me with music.
#132 |
Hello Guy,
To refresh the topic I would like to ask discuss two issue: - Is anybody who use power amplifier to measure impedance and what is the voltage influence on resonace peak. Soundcard supply about 0,1-0,3 mV but I checked it with small amplifier 2-4V. I Expcected change in fs result but there was not big difference. - My measurments are higher than technical information of speaker about 20-30Hz. I measured few speaker to avoid mistakes and in all cases look the same. Graph, peak, phase look very good but peak is moved. Do you knw the reasons? |
#133 |
I just found a way of utilizing built-in microphone preamp in Presonus FireStudio Mobile soundcard for dual-channel mode measurements with ARTA. That means dropping the need for separate mic preamp. Is anybody interested?
#134 |
it could be usefull to share it tnx.
#135 |
Ok, have look at the attached guide. I've also sent it to ARTA for review, no comments so far. I hope it doesn't have major faults.
Jānis Setting up Presonus FireStudio Mobile for dual-channel measurements.doc |
#136 |
tnx janis,good stuff
#138 |
The Focusrite Scarlett2i2 (&TASCAM US 122MkII) is 2in-2out unlike Presonus FireStudio Mobile which has more than 2 ins allowing to connect the way PRTG has described well. Since the mic preamp out is internally connected to line in, resistor R5 cannot be inserted in between. This means proper value for ext left preamp gain cannot be entered in ARTA without having to compromise. ARTA application note no. 1 states on page 6 " There can be other way for the realization of switch box in cases when soundcard has embedded a high quality microphone amplifier (i.e. TASCAM USB-122) or when soundcard has phone output that can drive relatively low impedance. Such cases will be described in other application notes." When can such a note be expected? I emphasize: I do not want to compromise by putting R5=0 and let the 2 channels be driven by different source impedance. Any help in this regard is highly appreciated.
#139 | |
Generally you need to see at least 3 pairs of ASIO (DAW) channels in ARTA but use only 2 of them there and third one leave alone for mic (in isolated way). Then route out- DAW channel defined in ARTA to one output and out-channel of mic-in to the secondary output. If you're confident that it can't be done with particular card then you'll obviously need separate pre-amp for mic. I had a quick look on Focusrite answerbase Have a look what choices you have at The Routing Section for monitor-out and phones-out and see if you have more than one DAW choice here. Wishing success in either way, Jānis |
#140 |
From Focusrite Answerbase:
Can I use Scarlett MixControl with the Scarlett 2i2? No, the Scarlett 2i2 is not compatible with Scarlett MixControl. All of its controls are hardware based instead. The mic preamp section is supposedly good and I do not want to spend on another mic pre How about sketching the mic preamp section of the unit, calculate the output impedance and insert the necessary resistor? I think it is built around NJM2122 but the task is daunting as it is completely SMD. |
| Help with Arta- HOLMImpulse | viki_v2 | Software Tools | 2 | 12th September 2012 02:04 AM |
| Arta box. | miklos | Equipment & Tools | 1 | 29th July 2012 04:45 PM |
| arta vs cliowin | ermes | Multi-Way | 0 | 4th March 2011 02:37 PM |
| ARTA - using ARTA to measure room acoustics! | OMF | Software Tools | 0 | 25th November 2009 01:55 PM |
| ARTA help | Cousin Billy | Multi-Way | 2 | 13th February 2009 12:16 AM |
