I’m designing a mid-bass array to augment an ESL panel with. This line array will be 4’ long and should handle the frequency ranges of 85 to 450hz.
I’m looking to get good near-field coverage of distances of up to 14’ away from the drivers. I’m currently thinking of stacking 6 Adire Extermis as closely as possible into the 4’ height. I’ll be using power tapering of the two outer speakers to maintain focus. My biggest question is will this give me the kind of SPL at 12’ to 14’ to keep up with a 4’ by 12” ESL panel? Are there other designs of line arrays with the extremis out there?
Jonathan |
#2 |
A pro sound midbass might be better suited to your needs. Something like the B&C 10PLB76 10" woofer.
http://www.partsexpress.com/pdf/294-659.pdf You would only need 4 of them for your array. |
#3 |
I think that the Extremis drivers would be really great. If you wanted you could push that 85HZ high pass down quite a ways and eliminate the need for a sub.
nate |
#4 |
I would also not recommend power tapering of the woofers. Do some searches on line array theory and driver spacing. Read Griffin's line array white paper too. Most of the information that you need will be found there.
With the upper frequency that you are working with, you might be able to space the drivers out a little more and create a taller line source without any lobing. There are many benefits to this and at your listening distance, you will take advantage of many of them. You will be loading the room (with bass) vertically. This will help a great deal with bass nulls. Sounds like a great project. Which stat panel are you using? Nate |
#5 |
frugal-phile(tm)
Typically ESL panels are even less efficient than the Extremis (and that is before factoring in 6 of them). As long as you supply them with a baffle that supports them down to their cutoff they will be fine i'd guess. If the ESL isn't power tapered i wouldn't bother doing that with the extremis.
And i assume you are multi-amping? dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 | |||
The Sub stays, plus, it’s part of the room now Quote:
While I would like to have a longer array, I’m constrained by the height of the screen and the fact that this will mount to the top of the IB Sub manifold (my sub is the first ‘Outie’ inverse manifold IB). As you can see from the pics in my IB Build story, the array would sit on top of that Sub box, which is a 22” cube. So the top of the array is at 22+48+2 = 72”. The stat panel comes from a Martin Logan SL-3, as will the associated electronics. The housing from the original SL-3 will be ‘modified’ (i.e. the woofer cut off) to build this. Quote:
Bass – 85Hz crossover to Infinite Baffle sub, 24db / octave LR MidBass1 – 85Hz highpass, 24db / octave LR, 450 low-pass 12db / octave MidBass2 – 85Hz highpass, 24db / octave LR, 250 low-pass 6db / octave, delay, limiters Highs – 450Hz highpass, 12db /octave However, based on what Nate said, it sounds like that’s overkill for these frequencies. I do have a 800 w (4 ohm) Sunfire amp channel dedicated to the ESL panel, and still have another 3x200 w (8 ohm) Sunfire amp channels to play with for this project. So splitting the array up is easy, but if not necessary, then I won’t. Thanks for the feedback and keep it coming.
Jonathan |
#7 |
One more thing: Enclosure design
Adire’s guidelines are for roughly 9.5L per driver in a sealed alignment, therefore the line array box is a simple tower that measures 48”x10”x12.5” to yield an internal volume of roughly 60 Liters in a sealed alignment. Using six internal braces for reinforcement, the box is pretty simple to construct. All sides are 1” MDF. As the speaker is never really visible, the finish will be flat black paint. Any opinions on the use of sealed vs vented for this application? Sealed would be simpler (and smaller). Thanks,
Jonathan |
#8 |
frugal-phile(tm)
I'd think you'd want to maintain the dipole as far down as possible (ie extremis in an open baffle)
dave
#9 | |
Dave, I’m, precisely trying to avoid dipoles at these frequencies due to rear wave cancellations. The ESL panel will readily play down to 250Hz, but the cancellations are severe and cause a noticeable suck-out. I’m looking to get clean, high SPL’s from 85 to 500Hz out of the line array. Power is not a problem (I can do 2x200w into the array), so a sealed design seemed like the best way to achieve this. Again, as the center channel, the music and vocal ranges are often concentrated there, and I’m looking for a strong mid-bass foundation that will keep up with the ESL and the IB sub in terms of clarity and ultimate SPL.
Jonathan |
#10 |
Here is the rendering for this project.
Again, a sealed box with six series/ parallel connected Extremis: Opinions or constructive criticism are all welcome.
Jonathan |
| Mid-Bass line array – Design & Driver Q’s | JonFo | Multi-Way | 1 | 7th August 2007 12:17 PM |
| line array + transmission line ? | zobsky | Multi-Way | 12 | 16th August 2006 04:18 PM |
| Extremis 6.8 as a dedicated bass driver | SCD | Full Range | 9 | 9th January 2006 06:07 PM |
| Line array tweeter line - On left or right? | dhenryp | Multi-Way | 4 | 9th March 2005 11:35 PM |
| how to combine Line array and transmission line together | Jared | Multi-Way | 5 | 19th April 2004 10:32 PM |
| Page generated in 0.12067 seconds (82.31% PHP - 17.69% MySQL) with 11 queries |
