Still trying to sort out whether to build some other type of cabinet or horns. My understanding through older literature is that if the horn path differnence through say a low and a mid leads to a delay of over two milliseconds between the two then it is hearable, I don't know if this only applies to large halls or would be detectable in average living rooms. Does anybody have any experience to clarify this?
Looking forward to any replies. jamikl |
#2 |
2ms in the bass range is trivial!
All speakers will have group delay which is effectively a delay with respect to frequency. What is audible depends very much on frequency but 2ms in a BLH is nothing to worry about.
Red Spade Audio Blog | Writer for: Hifi Zine S3 Synergy horn + 18" active woofers + T20 horn sub + B&C active surrounds + Custom Acoustic Treatment |
#3 |
You might think it makes a difference, you could sit and calculate that it would, you could read about it, but amazingly when done well, a BLH sounds great.
More effort should be put toward rolling off the horn to avoid mid nulls, and room integration IMO. |
#4 |
Thanks for the replies paulspencer and Indm. I agree Indm. They can sound very good indeed. It was easier before we had the simulations I think. I have done several on BLHs that I know sound good but the sims never look good!!!! Makes me wonder if we are barking up the wrong tree as to what contributes to good sound. Must be a lot more yet to be understood!
jamikl |
#5 |
A lot more to be learned indeed (or did we always know it?).
I recently lead lined my cabinets only to find I miss the vibrations! The sound is more accurate but more, ummm, boring I know it will be better in the end though, I'll just have to wade through my coupling cap and valve collection first. Where does it end? |
| smith horns and using compression horns for a Karlson party speaker project | bikehorn | Multi-Way | 14 | 30th January 2013 05:20 PM |
| echo, reverb using bucket brigade delay lines from panasonic | Workhorse | Solid State | 20 | 6th April 2011 12:37 AM |
| cassette tape echo / delay | thegunshyboy | Instruments and Amps | 10 | 23rd November 2006 11:36 PM |
| PT2399 Echo / Delay Audio chip | -_nando-_ | Digital Source | 1 | 28th August 2006 02:53 AM |
| DIY digital audio delay?(horns) | mike.e | Digital Source | 6 | 7th February 2005 11:10 AM |
