Looking for a good quality DIY design...Please help
Old 16th November 2002, 04:40 AM   #1
philcav7 is offline philcav7
Post Looking for a good quality DIY design...Please help
Hello. I am new to this forum and I am very glad that I found it.
I have decided that I would like to build a pair of speakers(or more). A video shielded speaker would be prefered but not required. I was wondering if there are any favorite designs that are very popular and fairly inexpensive.
I have great woodworking skill and have built many, many subwoofer enclosure so I have capability of moderate/advanced cabinet designs.
I desire a full range speaker that has excellent imaging, with a light, airy sound...but not thin. Stong, pronounced bass, with a nuetral, full bodied midrange.
Any info inluding links, specs, designs, or parts list would be great.
Thanks in advance.
Old 16th November 2002, 11:14 AM   #2
paulb is offline paulb  Canada
I'm building these, from a diyAudio.com recommendation:
http://www.partsexpress.com/resource...ayton_iii.html
Old 17th November 2002, 01:56 AM   #3
Al.M is offline Al.M  Myanmar
If this fits into your budget this would be it:
http://www.geocities.com/diyproac25/
see past comments on this project "Proac 2.5 clone"
If you want to make it cheaper use 50c to $1.00 type crossover parts, it will still be about 80% as good as the expensive parts.
Old 17th November 2002, 03:16 AM   #4
dshortt9 is offline dshortt9  United States
dshortt9's Avatar
I agree on the ProAc 2.5 clone. One of the best things is that you can audition one before deciding to build it to see if it fits your needs. My clones are outstanding and worth every dollar.
Old 17th November 2002, 06:35 AM   #5
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: Looking for a good quality DIY design...Please help
Any idea on budget... there are a lot of good choices that would help narrow it down.
The BD-Pipes cover your bases except for the deep bass -- but that is the job of the active sub. These scale price wise depending on the version of FE103 you use.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th November 2002, 05:24 AM   #6
Great! Thanks for the suggestions. Keep them coming.
I am sorry, I did forget to mention the rest of the system. Most likely I will have a DIY tube amp (one in the sub $1000US range) or lower priced amp such as Parasound, B&K, Krell, and others.
I listen to a variety of rock, pop, blues, jazz on CD...no vinyl.
I will have the speakers in a mid sized room about 8ft listening distance.
My budget is up in the air at this point but I would like to keep it in the $600-$800 range for speakers and components(not including cabinets)
What about DIY designs using Seas drivers, I am not familiar with them but I hear that they are great speakers. How do they compare to the Scan Speak? Also, any comments on the Adire Audio KIT281, They are a great speaker for HT but how are they for music?+
Thanks again.
Old 18th November 2002, 05:51 AM   #7
frugal-phile(tm)
planet10's Avatar
I'd approach this as a powered sub (a pr preferred) + mini-monitors/satellites.
Has a lot of advantages, flexibility being the key one.
1/ to get the best bass the speakers usually need to be in a different place than for best imaging.
2/ the bottom & the top can be upgraded independently
3/ you are bi-amping right off the bat.
dave
Old 19th November 2002, 03:01 AM   #8
I hadn't really planned on a separate subwoofer but I can certainly accomodate that, I have plenty of experience with subwoofer design.
Old 19th November 2002, 04:51 AM   #9
frugal-phile(tm)
planet10's Avatar
I had noted that from a previous post you made.
Not having to worry about the bottom makes it a lot easier to do the rest. A smaller driver tends to cover the midrange better and since it is also more extended at the top you can push the XO frequency to the tweeter up higher making the job of the XO easier (my BD-Pipes XO at 10k, just a simple cap).
Here is a more convential DIY design that would go nice with sub(s). http://www.geocities.com/kreskovs/ls35aclone.html
And there are MANY more. Shall i go on...
dave
Looking for a good quality DIY design...Please helpHide this!Advertise here!
Simple, good quality DAC jnxw2 Digital Line Level 75 5th November 2012 01:12 AM
Good quality 6600 CT OT Valvomaniac Tubes / Valves 4 2nd April 2007 09:56 PM
Good Quality Sub krillan092 Subwoofers 1 19th January 2005 09:25 PM
Good quality CD player fireman Everything Else 5 14th June 2004 09:55 PM
Copyright ©1999-2017 diyAudio
