Hi.
Been thinking about this for a few days. I would like some input on the general idea and input on driver-selection. I'm not going for super-hifi, but for an alternative speaker that cheap to make. The Idea is to use a cardboard-tube for cabinet. The dimensions would like 18 cm diameter and height about 1.20-1.60m. Thickness would have to min 10mm. I would probably use 4 (or 5) 4" or 5" bass/mid-range/full-range units and a tweeter. If I go all the way, it should bed an active speaker as I have most components to do 6 amp-channels. I have a lot (10-12) old full-range Philips units and I might use them for a first try. They a crappy looking and only 12W a piece, but it might just work. So, any ideas on the driver selection before i decide to make this or not? Whats the price for 10 4" units with acceptable data? Regards TroelsM
Need more time... |
#2 |
Here's a quick drawing shoving the idea.
Any inputs? Regards TroelsM
Need more time... |
#3 |
frugal-phile(tm)
A 2 1/2 way or a 3 way? Some of those old Philips are pretty good -- they do need mods to get the most out of them. Which ones do you have?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Hi Dave.
I haven't gotten the detail figured out yet. Right now it's only a feasibility-study... If I'm gonna´ make an active system I might as well go all the way and make it a 3 way... Don't know. I have to think about getting the most "volume" out of the small units... I'll try to find some data on the Philips units. As I remember they are approx 5", 12W and with a paper-diaphragm. Voice-coil looks to be aluminium or perhaps copper. VC-diameter is approx 15mm. Have you got any links to info about these old Philips-units? Regards TroelsM
Need more time... |
#5 |
frugal-phile(tm)
Here are a couple sites with some info:
http://www.hupse.nl/radio/speakers/A.htm http://www.sitecenter.dk/otc/nss-fol...lipsfullrange/ Most have an ADxxxx number on the back. I have some info culled from my eBay auctions. http://homepage.mac.com/planet10/vin...llery/philips/ dave
#6 |
Hi Dave.
My units look as if they are somewhat newer than the ones in your links. Sadly the ones you link to look much better than mine :-( Anyways, I'll try to find some data or numbers on them. Regards TroelsM
Need more time... |
#7 |
Here's a shot of the units I'm planning on using:
Do they look familiar? Regards TroelsM
Need more time... |
#8 |
And the backside:
The label is hard to read. My mistake. Regards TroelsM
Need more time... |
#9 |
http://www.linkwitzlab.com/Pluto/intro.htm
Is worth a look if your considering active. Personally I'd reflex them low. |
#10 | |
frugal-phile(tm)
dave
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| "Void free" or "no core gaps" plywood | rick57 | Multi-Way | 6 | 14th March 2007 01:09 PM |
| Where does "fullrange" end and "two-way" start? | KCHANG | Full Range | 55 | 1st December 2006 08:21 AM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.11900 seconds (75.88% PHP - 24.12% MySQL) with 11 queries |
